08-02-2019, 02:29 PM | #1 |
Wiper motor
I did some searching and talked to a couple of people and decided to clean up and reseal and lube my trico wiper motor. I tested it today off a vacuum line and it works pretty good.
Two questions. Does it mount above or below the bracket? See picture where bolts go. Next, from the control knob to the control arm on the motor. I think I'm missing something?? How does the knob control connect? In the picture you can see some wire. I'm pretty sure that is what I undid when I got it, only wire was between the two.
1950 Build |
08-03-2019, 01:16 AM | #2 |
Re: Wiper motor
this is the way, the screws go through the bracket into the wiper motor. there is a piece of linkage that is supposed to be there, I bet you can find it on chevsofthe40s or another bone stocker site like that
08-03-2019, 01:12 PM | #3 |
Re: Wiper motor
Thanks joedoh! A little change in wording and I got one coming. 3 bucks. Called linkage control rod.
1950 Build |
