05-12-2021, 11:20 AM | #1 |
Radiator Drain Valve ?
I need to drain the radiator to remove intake manifold. I tried to turn the little spigot on the bottom but it’s stuck pretty good. I hit it with BP Blaster and figured Id leave it alone overnight. Any other suggestions to get it free ?
71 C-20 07 Magnum RT AWD |
05-12-2021, 11:27 AM | #2 |
Re: Radiator Drain Valve ?
is it the original copper brass radiator or a new aluminum with a plastic spigot?
1967custom |
05-12-2021, 11:53 AM | #3 |
I always get confused on which way to turn them...are you turning it the correct way?
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
05-12-2021, 11:58 AM | #4 |
Can give it a few light taps with a hammer to hopefully free up the stuck drain. Sometimes works sometimes doesn't. The old pull the lower hose works too just messy.
1969 Chevy c20(Miss Hackjob) |
05-12-2021, 12:32 PM | #5 |
I have found it easier to slowly disconnect the lower hose at the tank to drain a bit of fluid.
1971 SWB step side: Original NM Forestry and then NM Fire truck |
05-12-2021, 12:36 PM | #6 |
Thanks guys ! The radiator is the original brass/metal one. I have learned from past mistakes NOT to try to unstick stuff that’s not been moved in years. I tried tapping it with a small hammer but it didn’t budge. I think loosening the bottom hose sounds less dangerous...
05-12-2021, 02:29 PM | #7 |
For sure...
Careful with things like that. Step one: Think a sec, if it does break, where would that put me? Sometimes no worse off, sometimes it could leave you with a bigger problem. The last work I did to my truck, last summer... Tried to drain radiator My drain plug broke right off. Cost me a new radiator. |
05-12-2021, 02:39 PM | #8 |
The threads on my metal drain are backwards (left-handed). It threads into the radiator to open, so turning it counterclockwise opens it.
05-12-2021, 02:40 PM | #9 |
I have drained my 72 by siphoning it out through the radiator fill hole. I used a piece of 1/8" ID tubing (maybe 3/16") and a 5 gallon bucket. It was a bit slow, but not messy at all.
05-12-2021, 03:22 PM | #10 |
If it's a metal petcock and not a plug, you don't need to remove it from the radiator.. It's perfectly OK to use pliers to loosen it.. It opens by turning it counterclockwise..
05-12-2021, 05:07 PM | #11 |
Thanks again fellas ! I used my head and let it sit overnight. Taped it again with no luck so I tried backing out the entire spigot from the tank. I got it to move so hit it again just now. Patience is something you learn over time. ...
05-12-2021, 07:23 PM | #12 |
20' Daredevil (Ret)
.... Often after breaking several things first....
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
