Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 08-16-2021, 01:16 AM   #1
dagnabbitt
dagnabbitt's Avatar
Yukon XL 2500 Wheel Selection
I have an interesting question, at least, I think it is interesting. I have a 1968 C20 I am building, and one of the early purchases I made was a set of new tires, 235 85 16's, mounted on eight lug Econoline wheels that I got for free. I did it almost exclusively because I could not stand to look at the old (incorrect) split rims and tubed tractor tires. I had the money, at the time.
Here's the thing: I am now two years into this project and have maybe two miles on these wheels. Meanwhile, my 2010 GMC Yukon XL is in need of new tires and I am feeling the pinch after a crate engine purchase, etc. I see modern HD2500 wheels on the 67-72's all the time... is there a reason why I cannot do the reverse? Has anyone put wheels like these on a Yukon 2500 before?
The tire profile between the 235 85 16's and the factory 265 70 17's is virtually identical: aside from being slightly narrower they are nearly exactly the same height/diameter and being 10 ply they would work well. Eyeballing the brakes, I think that 16 inch wheels would fit. I would have to take a look at the backspacing/offset. But it would be great if anyone has done this before and could give me some tips.
I should mention that these are the nubless Econoline wheels so I think they would look good painted black with the modern 2010 hub hardware: I still plan to get nubbed ones for my 1968 since it will run OG dog dishes.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 08-17-2021, 07:15 AM   #2
Re: Yukon XL 2500 Wheel Selection
The only thing I can think of is will the 16" wheels clear the Yukon's brake calipers. I had that problem on another vehicle. The 16s rubbed the caliper, while the 17" rim just cleared them. Other than that, they should work fine.
Old 08-17-2021, 11:18 AM   #3
dagnabbitt
dagnabbitt's Avatar
Thanks for the input! I am hoping that the brake calipers are the only issue. I think they will clear. But only one way to find out, I guess!
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 09-08-2021, 11:01 AM   #4
eager_adventurer
Love those basic steel rims. It's just like the Vision galvanized mod steel rims that I saw on 4wheelonline.
eager_adventurer is offline   Reply With Quote
