what headers are you running
just got a 383 crate motor for my 66 C10. i can only find one set of hooker headers that will work. Looking for Steel, Silver Ceramic Coated. Anybody with this set up out there.....What have you guys found that works?
http://www.summitracing.com/parts/HOK-2452-1HKR/ thanks for the feedback.
The price of cool aint cheap. |
Re: what headers are you running
Willy you looklng for full length or 3/4 ....here`s a set from sanderson
http://www.sandersonheaders.com/Sand...eader-Set.html
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
thanks rich......Ouch!
when you add the Thermal Coating... anybody else?
Ok..didn`t mean to beat you up.....
![]() Join Date: Mar 2012
I have Hedman 69096 ceramic coated on mine , work well , a little bit of tweaking of clutch linkage if you run manual trans. Nothing serious at all, I am happy with fit.
I also found them at a swap meet for 150 dollars new never used, which also made me HAPPY! Last edited by MARTYZ; 09-30-2012 at 08:57 PM. |
I had a difficult time trying to find headers that would fit with manual linkage. I ended up going with block hugger headers. They fit nice, look good and it was easy to build exhaust from.
65 short step edited by staff |
60-66 Nut
The Hedman #69260's are designed to fit these trucks with a small block, but they have only 1-1/2" primaries. The Hedman #69090's are designed for newer trucks but will work in these trucks just fine with either manual or automatic trans. They have 1-5/8" primaries. Those numbers are for plain steel. Ceramic coated headers are available with just one number change.
MARTYZ, is your truck lowered? $150 thats a good score.... my truck is lowered 4" in the front and 6" in the rear. both hedman and hooker say these are for stock ride height trucks only. do you drag on speed bumps or driveways?
Mine is down a bit, 2.5 drop spindles in front and bags in rear , not draging but I would not want to be much lower than it is, Get you some photos of clearance i have and some measurements
Willy, camera batteries dead, 9 inches from floor to frame and 5 inches from floor to lowest point of headers, engine and trans on origonal stock mounts. Basicly headers are 4 inches lower tham frame rail, measured at front cab mount. Hope thaat helps!
thats what mine are now, they sit about 4 inches lower tham frame rail and i never had any problems.
in the past i have had problems keepeing the header bolts torqued down. anybody use those header bolt kits with the retainers? do they work or are they junk?
http://www.summitracing.com/parts/stg-8911
65 C10 Thorley Tri-y headers, 350/350, Flowaster 2 chambers, Side dump in front of the rear wheels. Love it!
65 C10 Long Fleetside |
