Old 11-16-2021, 09:33 PM   #1
skip99
skip99's Avatar
Fuel regulator and gauge
Apparently i need to add a reg. And gauge for my sbc with edelbrock carb, whats a good looking cheaper combo or whatever that works ?
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 11-16-2021, 11:06 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Fuel regulator and gauge
Im using a low pressure pump from summit - Fuel pump jm1003bk and a mooneyes gauge, never goes over 6 psi.
Old 11-16-2021, 11:07 PM   #3
Ziegelsteinfaust
Are you running a mechanical or electric pump?
If your running a electric pump. Use a bypass regulator. It keeps the pump cooler, and running longer. They do not like dead head pumping. Which reduces their life span.
If you have a mechanical either works fine. A dead head since it is cheaper to install, and a bypass if you have fuel temp issues.
Ziegelsteinfaust is offline   Reply With Quote
