Old 11-27-2020, 03:44 PM   #1
mike in mo
Front bumper mounted spare tire
Got a 94 k2500 with a slide in camper and getting to the under mount spare is a pain thinking of building a mount for the front bumper. Anyone done it ? Any issues to worry about? Any pics?
mike in mo is offline   Reply With Quote
Old 11-27-2020, 04:01 PM   #2
Re: Front bumper mounted spare tire
Only thing I have heard of is the cooling/overheating possibility. The tire will block most of the air flow from going directly thru the radiator, so make sure you leave a decent gap between the spare and from of grill so air can get into the radiator.
Old 11-27-2020, 10:29 PM   #3
Ironhorse
Ironhorse's Avatar
Used to see just such a spare tire mount style on the earlier square body trucks in the late 70s into the 80s. Was quite popular then with the amount of bed mounted cab over campers of the times. Good advice about the spacing out from the grill for air movement. Be sure you have a good radiator/fan shroud and proper fan/clutch and water pump. Don't see it much today but used to be quite prevalent on the road. Thinking welded braces and upright coming up off the front frame horns is the ticket. Good luck.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 11-28-2020, 01:08 PM   #4
1976gmc20
Yeah, I used to see them all the time and never heard of anyone having overheating problems, but it probably depends on the climate.
Did the original crank up mechanism fail? I'm not sure why some aftermarket outfit isn't making a heavy duty replacement? Or one could get the spare crank/winch off of a newer junkyard pickup and adapt it to the GMT400 frame.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 11-28-2020, 02:04 PM   #5
mike in mo
Thanks guys I'm going to give it a try . My 79 g20 van has a front mount and dont run hot hope for the best I guess. No the factory stuff works but my camper hangs over the bumper so I can't get to the tire winch hole.
Old 11-29-2020, 12:59 AM   #6
Just call me Sean
Just call me Sean's Avatar
This is mine. I made it from a van tire carrier and bolted it to the brushguard. No cooling problems, this is Florida and I always pull a trailer with the a/c cranking.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 11-29-2020, 02:40 AM   #7
mrtoni
I have this one for 70’s Ford. Pretty simple design
mrtoni is offline   Reply With Quote
Old 11-14-2021, 10:03 PM   #8
Your41Plague12
Your41Plague12's Avatar
I know this thread is a year old, but you wouldn’t happen to still have that and want to sell it, would you?
Your41Plague12 is offline   Reply With Quote
Old 11-14-2021, 10:16 PM   #9
mrtoni
I do have it and would sell it. My inbox is apparently full
Old 11-15-2021, 10:40 PM   #10
Your41Plague12
Awesome, I can’t figure out a way to message you since your inbox is full. Maybe shoot me a PM and we can work something out. Thanks!
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Old 11-16-2021, 05:10 PM   #11
mrtoni
How about $85 and shipping? I cleaned out in box too
Old 11-16-2021, 09:38 PM   #12
Your41Plague12
PM sent. Thanks!
Steve
