11-19-2021, 03:24 PM | #1 |
67 C10 door locks
I just picked up a 67 C10. The keys in the doors are acting a little funny. The driver side will only unlock it will not lock. And the passenger side will not unlock but it will lock. Is this a common problem?
Rob the ToonMan 56 Chevy Cameo----Custom, [Turquoise] 67 Chevy C10 Short Fleetside (Black & White) 63 Trailorboat-------Teardrop Style Trailer 69 Honda CM90 |
11-19-2021, 06:28 PM | #2 |
Re: 67 C10 door locks
Can you lock and unlock both doors with the lock knob? Both mine were froze up when I got my 67.
If you can move the lock knob up and down to lock/unlock it’s gotta be in the keyed part.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
11-19-2021, 09:13 PM | #3 | |
The Older Generation
Have you been trying it with the doors closed or open? I wouldn't call it common, but there can be a problem with the spring cover coming loose on the inside of the lock and only allowing the cylinder to turn one direction, or not turning at all. I have disassembled quite a few of them and re-staked the spring cover which fixes it. The first thing I would recommend is to roll the window down and with a good strong flashlight you can see the lock and latch mechanism by looking down inside the door at the back of the glass. Spray some PB blaster or other good penetrating oil on the lock & latch down through that opening and see what that does. LockDoc
11-19-2021, 10:00 PM | #4 | |
11-20-2021, 11:47 AM | #5 | |
Doing it that way will lube the whole latch mechanism. let us know what happens.
11-20-2021, 04:00 PM | #6 |
Okay with the door open it locks and unlocks fine. But the minute I shut the door it will only unlock. I looked down the window channel and everything seems to be moving around okay but I think I'm going to have to pull the door panel off
11-20-2021, 05:28 PM | #7 | |
If you have lubed the lock and latch assembly as I mentioned above, try pushing in on the door when you turn the key to lock it. LockDoc
11-20-2021, 07:20 PM | #8 |
I will try that LockDoc
11-21-2021, 01:18 PM | #9 |
yes you are suppose to get in on the driver side and exit on the passenger side. Think safety.
11-21-2021, 02:55 PM | #10 |
I pushed it and it works fine!!! Thank you
11-21-2021, 03:11 PM | #11 |
That's funny! I was going to say "sounds like they work as designed. enter driver side and exit passenger", but figured he might not feel like joking until he got it figured out.
11-21-2021, 04:07 PM | #12 | |
That means one of two things. The latch is worn out or you need to move your striker plate out about 1/16 of an inch. If you move the striker plate out mark around it with a fine felt tip marker first and don't let it move up or down, just out.
LockDoc
11-21-2021, 09:42 PM | #13 |
Excellent Lock Doc. Thanks
11-22-2021, 12:30 AM | #14 |
No problem. Post an update after you figure out a permanent cure. LockDoc
11-22-2021, 01:14 AM | #15 |
I'll check the striker plates tomorrow!!! Appreciate the help!!!!
11-27-2021, 12:31 PM | #16 | |
Only adjusted the striker plate and it didn't seem to make any difference. I still have to slightly push in on the door and then it will lock. But thanks for the advice though cuz I'm very open.
11-27-2021, 03:57 PM | #17 |
How new are the door rubbers? Sometimes it may act up like that till the rubbers get worked in.
11-27-2021, 04:09 PM | #18 |
Thanks for the nice picture.
I know exactly where you are at in Gladstone OR. Last edited by Accelo; 11-27-2021 at 05:03 PM. |
11-27-2021, 05:05 PM | #19 |
It's such a neat little gas station it's a great place to go for a photo shoot
11-27-2021, 06:32 PM | #20 |
The door rubbers are brand new
11-27-2021, 07:41 PM | #21 |
Bingo
11-28-2021, 10:28 AM | #22 |
Read the threads about all of the problems that people are having with there doors after replacing the door opening rubber seals. It will be an eye opener.
11-28-2021, 12:35 PM | #23 |
I will. thanks
11-28-2021, 12:37 PM | #24 | |
Adjust it out another 1/16th then. LockDoc
