11-15-2021, 01:49 AM | #1 |
Saginaw 3 speed to SM465
Ok guys I’m in the decision making process with what motor I’m swapping into my ‘77 C10. It currently has a 250ci/Saginaw 3 speed in it, I have a 350 SBC and a 454 BBC that I can swap in(the six is neat but I want a V8). If I do the small block I’ll probably keep the 3 speed, but if I do the big block I want to swap in a SM465 as well.
Does anyone know for sure what tranny crossmember I’d need for the 4 speed? I have Googled my ass off and can’t find anything concrete. I know I’ll need the tail end tranny mount bracket thingy(won’t be using a 50’s/60’s bell housing mount obviously) for the tranny, I just don’t know what crossmember to use. Crossing my fingers I can reuse the one I have lol Thanks! -John Posted via Mobile Device |
11-16-2021, 12:57 PM | #2 |
Re: Saginaw 3 speed to SM465
You may need a bell housing also. The nose cone for the throw out bearing may be larger on the 465. A lot of times with the square bodies all that is needed is moving the cross member into a different set of holes already pre-drilled in the frame
11-28-2021, 11:13 PM | #3 |
Who's got steelies?
I have an 83 GMC I bought off a friend a few months ago. When he bought the truck in '91, it was a 3-speed. He converted in to SM465 in 92, and based off the list of parts he bought for the conversion, reused the 3-speed cross member.
Been under the truck several times and looked at that cross member and it looks like it could possibly work with an auto trans as well...
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
