Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 06-09-2022, 04:10 PM   #1
docrock
docrock's Avatar
1942 Chevrolet Flatbed that ate My Brain
The story starts in 2010 when I pulled this truck home for 1500 and a friends trailer that I almost broke because this thing is so heavy
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 06-09-2022, 04:12 PM   #2
docrock
docrock's Avatar
Re: 1942 Chevrolet Flatbed that ate My Brain
The interior is was alright and it ran
Old 06-09-2022, 04:13 PM   #3
docrock
docrock's Avatar
I had dreams of what it could be, and this is where it started to eat my brain
Old 06-09-2022, 04:15 PM   #4
docrock
docrock's Avatar
Or this
Old 06-09-2022, 04:25 PM   #5
docrock
docrock's Avatar
In my neighborhood they decided to remove the roads, curbs, and driveway aprons. So the church down the street says "park your cars in our lot until the work is done". They didnt expect my truck in there yard so they had it towed away. I found out where it is and the guy says "no paper work no truck" I said no paper work huge time delay for you, getting it out of the tow yard. My friend has a yard and it takes 3 months for DMV to clear vehicles. Here is 200. and I left with it. I hauled to my newly acquired yard. If you look at other projects I have done you see the yard where I take apart the trucks. And here she is after I pulled the cab
Old 06-09-2022, 04:27 PM   #6
docrock
docrock's Avatar
engine
Old 06-09-2022, 04:30 PM   #7
docrock
docrock's Avatar
I think I was stronger then because the cab was no big deal to take off. I had acquired an original 1/2 ton frame and had new dreams of a small truck. The frame got 500 and the motor got 500 with trans
Old 06-09-2022, 04:33 PM   #8
docrock
docrock's Avatar
I acquired a 40 took the bed for myself since it was an original GM bed parted out the rest
Old 06-09-2022, 04:37 PM   #9
docrock
docrock's Avatar
Picked up a70 frame for free from a friend and my plans changed again. I could not believe the bumper bolted on and the running boards where in a good spot
Old 06-09-2022, 04:39 PM   #10
docrock
docrock's Avatar
Put the cab on. I built a 305 motor for it. Put a 700r4 behind it and I was going
Old 06-09-2022, 04:46 PM   #11
docrock
docrock's Avatar
Fit more pieces
Old 06-09-2022, 04:47 PM   #12
docrock
docrock's Avatar
fenders fit ok
Old 06-09-2022, 04:48 PM   #13
docrock
docrock's Avatar
frame cut for fenders
Old 06-09-2022, 04:50 PM   #14
docrock
docrock's Avatar
modified radiator support to fit frame
Old 06-09-2022, 04:51 PM   #15
docrock
docrock's Avatar
Grill is in and now its is a driving truck
Old 06-09-2022, 04:55 PM   #16
docrock
docrock's Avatar
If you follow the other 42 project, I ended up selling it, so now I want a 1/2 ton again so it comes back in the shop to be disassembled. To go for the S10 project
Old 06-09-2022, 04:58 PM   #17
docrock
docrock's Avatar
Disassemble
Old 06-09-2022, 05:03 PM   #18
docrock
docrock's Avatar
The new 305 went into the 49 Merc and I added TBI
Old 06-09-2022, 05:09 PM   #19
docrock
docrock's Avatar
Time to pull the cab
Old 06-09-2022, 05:11 PM   #20
docrock
docrock's Avatar
Up she goes
Old 06-09-2022, 05:13 PM   #21
docrock
docrock's Avatar
I have had this 89 rust van and finally quit driving it when the radiator blew
Old 06-09-2022, 05:14 PM   #22
docrock
docrock's Avatar
So out the motor comes
Old 06-09-2022, 05:16 PM   #23
docrock
docrock's Avatar
And she is out
Old 06-09-2022, 05:19 PM   #24
docrock
docrock's Avatar
So I post a free van on craigslist and its gone in an hour. No paper work, No wire harness no engine or trans and I put bad rollers on it
Old 06-09-2022, 05:23 PM   #25
docrock
docrock's Avatar
I set the motor in the 70 frame and it fits no problem. I pulled the plugs and they were very bad so I decided I better have the heads checked, because it over heated.
