02-05-2022, 12:31 AM | #1 |
All around good guy
Lift 1971 Suburban
Bought a RoughCountry 4" lift with front and rear springs, shocks, raised steering arm, etc etc.
Will be putting 900-16 tires on it when completed. |
02-05-2022, 01:28 AM | #2 |
Re: Lift 1971 Suburban
That will make a significant difference in stance!
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
02-05-2022, 11:06 AM | #3 |
6>8 Plugless........
That is going to look killer!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-05-2022, 02:24 PM | #4 |
All around good guy
Lift was installed. The front lifted 4" and the rear lifted 2". Measured from center axle to fender.
Called RoughCountry and showed them what was going on and I was told that the rear is taller and the rear spring is purposely 2" shorter to "level" it out. It is noticeably shorter in the rear by 2" (measured) The wheel looks off as I couldn't get back far enough to stand center. |
02-05-2022, 06:00 PM | #5 |
I think those kits are the same for trucks (with a lighter bed)
I had to add blocks to the rear to level my Suburban out. And an offset plate too get the axle centered in the wheel well
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe Last edited by Bigdav160; 02-05-2022 at 06:06 PM. |
02-06-2022, 09:38 AM | #6 |
My K20 has a 4" with 285-16 tires ...blocks on rear so my tire is centered in rear... I'm
Going to drop it down a little this year with ALCAN springs. |
02-06-2022, 03:41 PM | #7 | |
All around good guy
02-06-2022, 03:42 PM | #8 |
All around good guy
02-06-2022, 04:04 PM | #9 |
Yes...5" block in rear w 4" front springs...gonna do a 2.5" instead....burbs are super heavy on the rear so I'll
Get a buddy to measure all 4 corners so I can get it spot on |
02-06-2022, 06:05 PM | #10 |
Roadtrip!
Nice burbs... Nothing wrong with a lifted burb.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
02-07-2022, 05:26 PM | #11 |
All around good guy
I got it figured out. Added a Superlift Add-a-Leaf to the new rough country springs along with the OEM overload spring and it is now sitting level at all four corners.
Will post up all the data, parts, and photos soon. Night pic after getting it done. |
02-07-2022, 06:08 PM | #12 |
Looks right! Love lifted burbs!
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
02-07-2022, 07:34 PM | #13 |
All around good guy
Thanks. I'm glad it worked out the second time. |
02-08-2022, 04:24 PM | #14 |
What?
Looks great!
What wheels are those? OE or new Wheel Vintiques?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
02-08-2022, 04:42 PM | #15 |
All around good guy
Thanks!
Wheels: https://www.summitracing.com/parts/w...70604/overview Tires: https://www.cokertire.com/tires/sta-...ly-900-16.html |
02-08-2022, 07:37 PM | #16 |
What?
Did you have to run any wheel spacers for the offset?
I ran into this with the same wheel, just not the smoothie version on my '72 k10 PU. The wheel was too close to the disc brake caliper.
02-09-2022, 09:49 PM | #17 | |
All around good guy
Will take a pic with measurement for posterity. |
02-10-2022, 04:44 PM | #18 |
All around good guy
A couple of daytime pics of the lift and tire combo
02-10-2022, 07:13 PM | #19 |
What?
Looks great!
In case you haven't yet, be sure to make sure your front drive shaft is in good shape after the lift. In my case since mine was running at a very low angle for 30+ years when I raised the suspension, I found that the slip yoke was worn out and needed to be replaced being at the new angle.
02-10-2022, 08:29 PM | #20 | |
All around good guy
Great advice! Luckily everything checked out. The original owner didn't use it much so not much wear and tear on it. |
02-12-2022, 10:36 AM | #21 |
It looks really nice but man, I could not live with the rear axle so far forward in the wheel well. Move that thing back.
It looks like if you load anything in the back, or hook up a trailer, you're going to hit the quarters in front of the tires.
02-15-2022, 04:33 PM | #22 |
All around good guy
Thanks for the feedback. Once I get it flexed and settled will measure and see where it needs t be!
06-02-2022, 06:14 PM | #23 |
06-03-2022, 12:57 AM | #24 |
Axle moves back as suspension cycles up. Especially with higher arch springs. Bet most would be surprised how much if you cycle the suspension to full bump.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
01-05-2023, 04:22 PM | #25 |
All around good guy
