Van Neutral Safety Switch ?
Got a tilt steering column out of a gm van. Just Wondering what the correct neutral safety switch would be. The sliding tab seems too short to go in the slot in the column
Posted via Mobile Device |
#2 | |
The Older Generation
Re: Van Neutral Safety Switch ?
The terminals for the wire connectors are different on the van than the trucks so you will have to use the one for the truck if you already have a NSS on your column. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-24-2023 at 10:55 PM. Reason: wrong info |
#3 | |
Junior Member
![]() Join Date: Apr 2021
Looks Like I Was Trying To Use The Truck One In The Van Column
Do You Know Where I Can Find One? My Local Parts Store Was No Luck Thank You Posted via Mobile Device |
Sorry for the misinformation about the switches. I guess you could use either one if you have to cut a new hole lower on the column. You would still have to change connectors if you use the van switch. LockDoc
I Have An American Autowire Harness With a Pink and green Wire and 2 purple wires
#8 | |
Junior Member
Thank You
By Any Chance Do You Know Where I Can Find Either Of The Switches. Having No Luck. Thanks Posted via Mobile Device |
![]() ![]() Join Date: Jan 2005
Looks like you can buy both at O'Reilly.
Van = NS52 https://www.oreillyauto.com/detail/c...2?q=ns52&pos=0 Truck = NS5 https://www.oreillyauto.com/detail/c...s5?q=NS5&pos=0 |
Junior Member
Thanks Guys
Got The Switch. You Guys Wouldn’t Happen To Know The Screw Size That Holds It Down?
I See Guys Saying #6 x 3/8 But That Looks Like It’ll Slide Right Through The NSS Tab Holes Posted via Mobile Device |
#14 | |
I think the original screws have a built in washer on them. LockDoc
#15 |
Here are some measurements of the original screw style. It's a "B" type tapping sheet metal screw with a hex drive and a built-in washer.
Thread Diameter = .187" (#10) Thread Pitch = 16 tpi Thread Length = 5/16" Hex Drive = 1/4" You'll probably be able to find something like this at a hardware store: https://www.mcmaster.com/92525A550/ |
#16 | |
Thank You! Exactly What I Needed. Appreciate It Posted via Mobile Device |
#17 | |
Junior Member
#18 | |
#19 |
At the body shop.
Related question.
Motorhome column in old blue has no neutral switch. Wire is jumpered. Do those have a provision for the switch?
" That didnt make it any newer " " Dont antique the equipment " |
#20 | |
Junior Member
