08-18-2023, 09:15 PM | #1 |
cruise on L83 swap
67 Suburban with 2018 L83, 4l60E trans, trans X controller, dual air. Runs good, 20 mpg cruising 70-75 with AC on.
Problem: Dakota Digital Cruse control works but surges and hunts. DD not any help, last suggestion was have the accelerator reprogrammed. I would have tried that if I could find anyone in South Texas that had a clue what that is. Anyone had this problem and found a cure? |
09-05-2023, 10:28 PM | #2 | |
BMW & ASE Master Certified
Re: cruise on L83 swap
on hptuners site someone ran the OEM bcm + brake pedal sensor and cruise switch and said it worked aswell.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
09-06-2023, 09:12 AM | #3 | |
09-09-2023, 07:14 AM | #4 |
Thanks, that seems to be what I need, only problem is down here is is finding a tuner that doesn't look at you like a chicken watching a card trick when you try to explain what you want
09-09-2023, 08:19 AM | #5 |
I have a guy that can probably do it, but you must have HP Tuners to load the tune into your truck. I am guessing if you had that, you could probably make the adjustment yourself.
Either way, if you want the guys name, drop me a PM. |
09-09-2023, 05:56 PM | #6 | |
what pedal did you use with your swap?
09-25-2023, 08:37 AM | #7 |
Thanks all, been under the weather last couple weeks, will get back on it soon
