Old 03-22-2024, 07:58 PM   #1
duramaxguy
Disc brake booster upgrade
Hi all
I am putting a disc brake Dana 44 front under my 70 K20, replacing the original drum brake axle. I'm looking for advice of what brake booster to upgrade to that includes a proportioning valve to support the disc brakes.
Is there an aftermarket booster I should be looking at, or get one from a donor truck?
duramaxguy is offline   Reply With Quote
Old 03-22-2024, 10:55 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Disc brake booster upgrade
if you can find one from a donor truck that would be easiest, when i converted my 69 i had a 72 donor and swapped everything including the steel brake lines to the front end, booster, master, prop valve etc.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
Old 03-23-2024, 09:33 AM   #3
72c20customcamper
72c20customcamper's Avatar
I bought the setup from a member Pickmup trucks . Very nice setup
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-23-2024, 09:39 AM   #4
72SB
I bought the CPP one for my 72 manual disc/drum conversion to power brakes. Plug and play.
Or look into Tough Stuff dual diaphragm booster for better engine clearance, especially if you have a BB. Get the matching PV for disc/drum from them also or but a combo kit if the offer one. Made in USA
My CPP
72SB is offline   Reply With Quote
Old 03-23-2024, 11:05 AM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
My CPP
That is a nice, clean looking engine bay.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-25-2024, 10:08 AM   #6
jeffahart
jeffahart's Avatar
Originally Posted by duramaxguy View Post
Hi all
Why does your booster need to be upgraded? If you already have power brakes, all you have to do is swap in the axle, pull the RPV out of the front reservoir. See how it stops. It will stop fine! Prop and booster won't give you anymore stopping power. The big issues will be front and rear bias and the small reservoir as it will lower as the disc pads wear. I never felt I got enough of a bump in stopping power when I moved from drum to disc. But my main goal was to move off the open knuckle/drum axle to a D60. I, later, installed a hydroboost off the same 86 diesel I got the axle. The hydro gave a significant and noticeable improvement in stopping power.
j
White K20
jeffahart is offline   Reply With Quote
Old 03-25-2024, 10:42 AM   #7
old51sedan
old51sedan's Avatar
My CPP
I ended up with the dual diaphragm one for my setup so that I had enough room to install my air cleaner, it worked out fine for myself.
old51sedan is offline   Reply With Quote
Old 03-27-2024, 12:54 AM   #8
57taskforce
All about them K’s
57taskforce's Avatar
I much prefer hydroboost over vaccum boosters. That’s one of the best changes I’ve made to my 72 K20.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
