Old 12-16-2003, 06:01 PM   #1
SteedaLX
Question Jimmy dies when put in drive or reverse
I have a 1971 Jimmy 350 4brl. I just had the carburetor rebuilt and the guy tuned it for my truck. It has new plugs and wires. My truck starts up fine and idles with no problems; it also idles fine in neutral. If I drive it while the motor is cold it runs great; it feels very strong. Once it starts to warm up it goes to hell. If I pull up to a light or at a stop sign it will start missing and die. It will start back up fine but when I put it in drive or reverse it spudders and dies. If I happen to get it moving it will miss really bad, sputter and die. It is so wierd because if I come back the next day it will run fine for a while then do the same thing. Somebody said it could be the coil so I am going to replace it when I get home. Beside that does anybody have any other suggestions? I am going to take it back to the guy who does the motor work for me but I wanted to run through the basics before I took it in. Some also suggested I put an HEI distrubtor on it. Any help would be appreciated.
1971 GMC Jimmy
6" Superlift w/ 35" tires
Chattanooga, TN
SteedaLX is offline   Reply With Quote
Old 12-16-2003, 09:14 PM   #2
jhow66
jhow66's Avatar
Have you adjusted the idle mixture screws? Have you adjusted the idle speed screw. If it is not idling fast enough in netural it will die when you put it in gear because the convertor in trans will slow it down even more Did the guy adjust the carb after it was put back on truck?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-16-2003, 11:06 PM   #3
Leinie
Are all the Vacuum lines reconnected in the proper places ?! Was the timing reset with the vacuum advance disconnected and plugged ?
Leinie is offline   Reply With Quote
Old 12-17-2003, 12:52 AM   #4
SteedaLX
Yes he adjusted the carb after I put it back on the truck. It idles fine in park and neutral...it also idles fine when put in drive, for a while anyways. I checked the vaccum lines and everything looks to be connected. I assume if one of them were not connected it would not run right anytime. I don't really know anything about carbs so I will need to get him to look at that portion of it. I replaced the coil tonight and it was running fine.....it started raining bad so I didn't get a chance to ride around to see if the problem came back....hopefully tomorrow though.
1971 GMC Jimmy
Chattanooga, TN
Old 12-17-2003, 02:29 AM   #5
blazer1971
Remove your air filter and check your choke both when first start up and after it warms up and you start having problems.
blazer1971 is offline   Reply With Quote
Old 12-17-2003, 03:39 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
pickup coil in distributor?? sounds like what happened to me when mine went
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-21-2003, 08:22 PM   #7
da-burb
"Ochre Ogre"
da-burb's Avatar
Sounds like a vacuum leak. Symptoms are; with the carb choked and a vac leak it runs good. With the choke open and the vac leak it is too lean to run. At idle it would be fine, under load it would miss and/or die.
I would check at the base of the carb if you don't find any lines off or split. I would also check the vac advance on the distrib(could be a ruptured diaphram), listen at the brake booster if you have power brakes, and check to see that the Vac modulator is hooked up on the tranny if you have a TH350.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 12-21-2003, 11:34 PM   #8
SteedaLX
Not for sure if this could have anything to do with it but after I got it back from the guy who tuned the card it has been leaking transmission fluid. At first it was a little bit but now it is pretty bad. I haven't been driving it since it really started leaking. It looks to be leaking right up by the motor.
1971 GMC Jimmy
Chattanooga, TN
Old 12-22-2003, 12:05 AM   #9
krue
Designated A-hole!
krue's Avatar
What kind of tranny? Check your vacuum modulator, there should be a vacuum line running from the carb to the pass rear side of the tranny (if it's a th350). If the modulator diaphragm has a hole and the line isn't connected you could get fluid. You would also have a vacuum leak.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 12-22-2003, 10:14 AM   #10
SteedaLX
It is a TH350. If the line was not connected how much would that cause it to leak? This is a pretty steady drip until about a quart as leaked out. It pretty much stops then.
Thanks again
1971 GMC Jimmy
Chattanooga, TN
Old 12-28-2003, 12:40 AM   #11
robby
Semper Fidelis
robby's Avatar
Did you ever find out what was wrong with it?
72 Chevy C 20 with 402 For sale
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
robby is offline   Reply With Quote
Old 12-29-2003, 10:07 AM   #12
SteedaLX
I have fixed part of it. The transmission coolant line was what caused that leak. Which turned out to be really nice considering I was thinking the worst. I have checked the carb for any kind of vaccum leaks and nothing looks to be out of place. I haven't driven it but i'm sure it will do the same thing. I will probably take it to my friend this week and let him check out the carb....since that has to be it.
1971 GMC Jimmy
Chattanooga, TN
Old 01-13-2004, 11:36 AM   #13
SteedaLX
I took my truck back to the guy and he fixed it. He has the choke tied open and apparently it had come loose and was shutting. He said that was causing it to die.
1971 GMC Jimmy
Chattanooga, TN
Old 01-13-2004, 02:07 PM   #14
Grim Reaper
Choke.
It's not coming off once it's warmed up. It's flooding out.
I gave up on divorced chokes like your truck has long ago. Went electric of got 78 up Quads and coverted them to electric.
For the record I question what the heck he was doing with "Tie off the choke". Sounds like he has not got it hooked up at all. He's probably running the idle mix fat to make up for it with the cold weather. I bet your going to have more trouble when it warms up! I'd convert it to manual.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 01-13-2004, 10:22 PM   #15
SteedaLX
Correct when I bought it the choke was not hooked up; so he just used some plastic ties so it is always all the way open. Like I have said I don't know jack about carbs. Will this be a problem for me? I am thinking about getting one of the off-road carbs by holly or edelbrock.
1971 GMC Jimmy
Chattanooga, TN
Old 01-14-2004, 02:02 AM   #16
blazingfun
might ckeck if gas tank is venting properly
blazingfun is offline   Reply With Quote
Old 01-14-2004, 10:18 AM   #17
Blue Beard
Blue Beard's Avatar
In my mind what he did to the choke may lead to other issues down the road........so to speak.
He's a mechanic, why not fix it right the first time.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
