Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Suspension, Steering and Brakes
Old 04-16-2006, 06:27 AM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Lowering Blocks 101......
I have been messing with the Suburban's stance lately, trying to get it to sit properly.
I needed a couple of extra inches lower in the back. I decided to use a set of lowering blocks, and since lots of folks have asked me lowering block questions before, I decided to photograph the process.
Here's how I did it for $24.80 and a few hours of work.
First, you need the supplies....
Take one of your stock U-bolts to a spring shop and have them make you a pair that are 2 inches longer. If yours are messed up beyond recognition, tell the spring guy you need a pair of 3/4 thread, 24 inch long U-bolts for a 3 inch axle tube. He'll know what to do.
My shop charged me $21.80 for a pair of them, and made them while I stood there and watched...
Tx Firefighter is offline
Old 04-16-2006, 06:29 AM   #2
Tx Firefighter
Re: Lowering Blocks 101......
Next, you need a piece of 2 inch square tubing at least 14 inches long.
Make sure and get thick wall tubing.
Mine is an old fence post or something. It weighed 10 pounds, and my scrap yard sells for .30 cents a pound, so it cost 3 bucks.
Old 04-16-2006, 06:30 AM   #3
Tx Firefighter
Lay the holes and length out with a Sharpie marker....
Old 04-16-2006, 06:32 AM   #4
Tx Firefighter
Drill the holes next.
Notice, I use plenty of clamps. I don't like sudden suprises when working in the shop.
Old 04-16-2006, 06:33 AM   #5
Tx Firefighter
The finished block....
Old 04-16-2006, 06:34 AM   #6
Tx Firefighter
Then, everything gets a quick trip to my paint booth.
Yes, jealous guys, I have a paint booth. It's a 6 foot tall Davidson with a nice rack made of square tubing.
Also, notice only the highest quality paint products were used too.
Old 04-16-2006, 11:51 AM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Is that a pinion angle shim under the block?? Very good write up and cheap...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 04-16-2006, 12:08 PM   #8
Tx Firefighter
FrenchBlue, that is a shim you're seeing, but not a pinion angle shim.
I'm using an ECE susper track bar on this truck. It mounts between the axle and the trailing arm on the right side, so they give you the shim for the left side to make up for the bracket on the right side.
I hope this is clear, what I'm saying...
By the way, I set the axle pinion angle when I welded the axle saddles to the rearend. That's a 75 model leaf spring axle that I ground clean and converted to coil spring saddles for this truck.
I'm on the Instagram- @Gearhead_Kevin
Old 04-17-2006, 12:13 AM   #9
powell72
powell72's Avatar
Tx, is there an interference issue with the block and the right side panhard mount? I remember having a problem with that on one of my other trucks. Maybe I made the right block a little too long in the back.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline
Old 04-17-2006, 02:02 AM   #10
Tx Firefighter
No interference at all.
