04-20-2002, 12:40 AM | #1 |
go bucks!
plastic gear in tranny to hook up speedo.?
not too up on tranny's, but i have been told of a plastic gear of some type that is under a plate where your speedo cable hooks into your tranny. anyone know what i'm talkin' 'bout? this is on a th350.also i unhooked the cable at both ends to make sure i didn't have a dry cable tubing.it looked brand new and had plenty of lubrication.when i first got it,it used to bounce a lot.now it don't do nothin'.where can i get one of those plastic gears(if thats what it is), and how much do they run?speedo itself works fine.
------------------ '68 swb 350/350 w/edelbrock total performance-performer pkg.ceramic headers,2.5" delta-flow 40 series flowmstrs.no rust of the notorious mid-west on this one! see my truck at free photo-i under "'68 chevy truck"
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
04-20-2002, 04:52 AM | #2 |
Old member
Go to any trans. shop and they should have the gear, and will install it. You need to find out which gear you need also for calb. the speedo when done. The gear itself isn't that much, but having it installed maybe inless you can do it, are have someone you know do it.
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 71,factory tach,tilt for straight drive,gauges,ac,305 HO TPI with 700-R4 lowered,17" wheels www.geocities.com/chevy71tpi/main.html] www.picturetrail.com/Andy4639]
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-20-2002, 06:41 AM | #3 |
1969 Custom 30 wrecker
Chevy dealers should have them in stock. Remove yours and take it with you. If you speedometer has been accurate, simply match it up with a new one. There are different colors which have a different amount of teeth.
If your speedometer is not accurate, then it's a matter of trying different gears until it reads correctly. For that, I would recommend a shop as they should have plenty of good used ones laying around for just this reason. Beats buying 4 new ones! ------------------ 63 Impala*66 Chevelle SS*69 Chevelle*69 C10 Stepside*71 Cheyenne 20*72 Chevelle Parts for sale: http://www.angelfire.com/trek/mr409/items4sale.html
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
04-20-2002, 08:47 AM | #4 |
go bucks!
thanks bob,andy,i'll do that this next wk.then!
04-20-2002, 12:48 PM | #5 |
its all about the +6 inches
However, if your needle was bouncing, then stopped working, you are probably looking at a busted cable.
Have a helper in the cab watching the speedo while you lay under spinning the disconnected cable. If the speedo don't move, it's a cable.When the cable gets old, it gets springy and causes the bounce you described. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
04-20-2002, 07:25 PM | #6 |
If the cable is bounceing it needs to be lubed. Dont use greese because the first cold day wil snap the cable. Use speedo cable lube (very light oil with grafite)
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
04-20-2002, 07:47 PM | #7 |
There are two plastic gears involved,,the drive gear and the driven gear. The driven gear is simple to change, the drive gear is a little more work. My guess is your cable is at fault. If you want to check the condition of the gears you can back up on to a pair of ramps or jack up and secure the rear half of the truck with jack stands. By lifting the rear up instead of the front you won't lose much, if any ATF. Disconnect speedo cable from trans, remove the bolt and the clamp that holds gear housing into trans and gently pull unit out from trans. Make note of the position of gear housing in relation to the clamp for reinstallation. This will get you to the driven speedo gear. The drive gear requires removing the driveshaft, then the tailshaft extension housing from the trans. This will expose the drive gear,,which is removed by releasing a spring clip and sliding the gear off the output shaft.
------------------ 1971 C10 swb stepside 350/700R4/3.73posi Killingworth, Connecticut
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
04-20-2002, 11:40 PM | #8 |
go bucks!
thanks guys,i noticed that when i first got the truck the speedo was working, jumping, but barely working.since i disconnected both ends and pulled the cable completely out of the cable line housing,cleaned it, inspected it,and sprayed it w/a industrial type graphite spray,and reinstalled it,now nothing happens.before it would at least jump at 'round 35-40mph.thats what led me to believe that a plastic or a wear-prone- intended part had failed.i'm goin' to take it to a local tranny shop and let him check it out. at least now i have somethin' i can point him toward to look at.thanks again!
