04-03-2004, 12:46 AM | #1 |
67-72 Addict!
Post your GM part numbers here
I figured we should have a thread for factory part numbers for easy reference. Anytime you get a receipt from the dealer try to list the part number and name of part here. It doesn't matter how small the part is. It may help a fellow board member who is looking for an "oddball" part!. Lets try to keep this as simple as possible. Heres a few I have bought for my 70'. I hope these are valid everywhere, otherwise this post is useless.
Upper steering column bearing - 5679205 Chrome turn signal lever - 3909580 Turn signal switch - 1972751 Turn signal switch harness assembly for the above switch - 1894851 Turn signal cancel cam - 3902190 Detent seal for detent cable - 1262475 (350 turbo) Transmission filler tube seal (top hat later style) - 1259475 (350 turbo) Transmission filler tube seal (O-ring earlier style) - 6264902 (350 turbo)
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
04-13-2005, 05:14 PM | #2 |
Exterior door handles
#3927899 and #3927895 I read this on another post, can't vouch for it and I don't know which is left or right.
71 GMC 1500 LWB |
05-03-2005, 02:39 PM | #3 |
For 1973 1974 1975 1976 1977 1978 1979 1980 (as far as I know)
Fender right 14031990 Fender Left 14031989 Hinges 6262007 & 626008 Hood 15576465 passenger bedside 15597624 |
06-02-2005, 08:37 PM | #4 |
Here's the upper alternator mounting bracket for 67 thru 72. Still available as of this posting...... 3951338
Steve
1997 GMC Sierra Ext 1965 Mustang |
07-13-2005, 04:31 PM | #5 |
That bracket is the adjustment arm and for the drivers side and for a short water pump....
11-26-2005, 09:30 PM | #6 |
Re: Post your GM part numbers here
plug in harness for van tilt to 67-72gm no.1894851 flat to horseshoe
12-28-2005, 03:25 PM | #7 |
73-87 headlight switch GM #1995217
GM PartsDirect has it for $16 Classic Industries has it for $30 |
11-27-2006, 04:51 PM | #8 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=216274 |
01-01-2006, 01:59 AM | #9 |
Don't know if you can still order these but here you go:
3917809-stainless cab trim-under the back window 3997463-Longhorn upper bed pass. side molding..pic included |
11-11-2006, 08:53 PM | #10 |
7000 #'s of american IRON
73-80 (may be full run to 87, not sure) Roof Marker LENS 7505068
11-11-2006, 11:06 PM | #11 |
GM must have changed #'s again, the 5 cab light lenses I bought for my truck are part #684662 in the new style box. Here's some more in case you guys need specific ones:
Roof marker lens gasket, 69-72 Gr. 2.575-#12337943 (new # should be availbile at your dealer, old one is 3942898) Window regulator handle, 69-72 Gr. 10.797-#20348200 Gas tank neck grommet, 67-70 Gr. 3.008-#3886792 - this is a good # that any dealer should be able to get Winshield wiper switch, 2 speed, #1993432 Door handle escutcheon(black, paint to match), Gr. 16.270-#3939997 Brake light switch, Gr. 2.4447-#1261219 Windshield washer hose grommet(goes on firewall), #3746483 Interior mirror cover(usually black, I have two NOS and one is dark metallic green from GM), 69-72 Gr. 16.069-#3971007 Heater control switch, Gr. 8.852-#3840039 Hockey puck cab lens, 69-70 #5961757 Rear red sidemarker light, 69-72 Gr. 2.575-#916087 Front amber sidemarker light, 69-72 Gr.2.575-#915788(had three #'s on the box, all crossed out except this one) Clutch rod swivel, 67-72 Gr. 0.787-#3918467 Deluxe Delco radio knob, 69-72 #1991087, also has 1991072 on the package
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
11-13-2006, 09:04 PM | #12 |
sufficiently talented fool
Sport mirror part #'s. The mirrors and gaskets were still available thru GM about a month ago.
Left side mirror - 3981409 reinforcement - 6263291 gasket - 3987127 Right side mirror - 3981410 reinforcement - 6263292 gasket - 3987128
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
11-18-2006, 11:57 PM | #13 |
Do the Dew!
If I can relocate some of the papers that I wrote my 327 part numbers on, I just might hit you up on your offer. I have been informed by the previous owner that my truck came with a factory ordered, blueprinted 300HP 327. The number on the glovebox, and the spec sheet lists the engine option 04L30AC. (It has been 8 months since I saw this number, so I hope it is correct).
01-20-2007, 08:39 PM | #14 |
Active Member
Eaton 12 bolt car or truck posi. These are the only parts that are the same between car and truck posi.
Eaton posi clutch pack. 12524505 Eaton posi springs Green 50lb 3890899
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) Last edited by EFI70Blazer; 01-20-2007 at 08:48 PM. |
