10-14-2009, 08:03 PM | #1 |
Disc Brake Upgrade Reference Thread
In follow up to this thread http://67-72chevytrucks.com/vboard/s...d.php?t=364621 I would like to start a "wiki" on what parts are needed to do the disc brake upgrade. I am finding splintered information all through this board and I am attempting to put it all in one thread for future reference and use by others. Everyone's input will be much appreciated. As I get input I will edit the original post to reflect that information.
I am splitting this up in how I think people's trucks will most likely be configured as they need this information. Then I am sub dividing it in doing a cross member swap or just a parts swap. The years are split because it is my understanding that the framerails changed in those years. I have it split on engine configuration since they use different engine mounts. I realize that probably alot of it is going to be the same so I may need to combine some of these down the road. Again, everyone's help would be greatly appreciated!! ITEMS TO NOTE: Later model ('73-'87) suspensions have the rubber control arm bushings. They are less maintainence and less apt to make noise. Plus you can upgrade to urethane bushings if you want. (thanks CaptainFab) The front cross members are basically the same from 63-87 so it makes it an easy swap with updated parts. (thanks 502tripower) Replacing the entire cross member has the benefit that you can rebuild everything roll it under the rig bolt it up. Pressure Differential Switch - The pressure differential valve is the device that alerts you if you have a leak in one of your brake circuits. The valve contains a specially shaped piston in the middle of a cylinder. Each side of the piston is exposed to the pressure in one of the two brake circuits. As long as the pressure in both circuits is the same, the piston will stay centered in its cylinder. But if one side develops a leak, the pressure will drop in that circuit, forcing the piston off-center. This closes a switch, which turns on a light in the instrument panel of the car." (thanks joe231) This wire is supposed to go the ground side of a warning light. For donor parts of a 80-87 they must have the 1-1/4" rotors. The 80-87 year spindles also came with 1" rotors and are 'light duty' and won't work with the 6-lug rotors. Yes-- You can pull the crossmember out with the motor still in place. I did lift it slightly with a engine puller just in case. The 6 cylinder is resting on the motor mounts with just the top frame bolts. (thanks bubba327) You dont need a spring compressor to remove the coil springs. Jack up the front, set it on stands. Put your jack under the lower control arm. Loosen your castle nuts, DO NOT REMOVE, and wack that spindle with a hand sledge...They pop right apart generally. Then remove your castle nut and slowly and carefully lower the jack until you can pop out the spring. It straight forward, but its work. (thanks protrash64) ADDITIONAL WORK REQUIRED ON ALL: When you do these swaps, it also requires the addition of a split brake system, with a line for the front and one to the rear. I will be researching this information soon but for the moment the easiest thing to do is if you get the whole cross member, grab the lines and booster/mc as well even if you are going to replace it you will know what lines/hoses to run (thanks bubba327) 1960-1962/5 lug Crossmember Swap: 1973-1987 (Chevy or GMC, 80-87 must have the 1-1/4" rotors.) Great how-to write up Here Here is a great writeup/howto on a method of converting a 60-62 GMC V6 to a 350 Chevy small block engine with a tail shaft mounted transmission. This would apply to a Powerglide or Turbo 350 automatic, or manual 4 speed transmission such as the Borg Warner Super T10, or Muncie M21 or M22. Most of what follows also applies to Chevy trucks for 60-62. The main difference being the GMC motor mounts are welded to the frame and the Chevy mounts are bolted on. - Thanks markeb01! Parts Swap: (Not possible since the original suspension came with a torsion bar setup ?) 1963-1966/5 lug Crossmember Swap: '73-'87 front cross member bolts in with drilling/elongating a few holes (it will become a 5 lug) The V8 and the I-6 (except the 292) perches are the same for these model years so it will bolt right up. (verification needed) Parts Swap: From '73-'87 you can unbolt the upper and lower control arms with the spindles attached and bolt these pieces onto your existing cross member. (clarification needed on 5-6 lug) OR You can re-use your existing upper and lower control arms and replace the upper and lower ball joints with new pieces from the '73-'87 donor truck. (clarification needed on 5-6 lug) Now, the steering linkage is slightly different for the 1966 to 1973/1987 models ( specifically the tie rod diameters ). There are a few different ways one can approach this situation, 1: purchase the adapter sleeve that mates your original inner tie rod to the later model outer tie rod - cost for adapters about 50 bucks , 2: remove the threads from the larger, newer model tie rod and retap the tie rod with a left hand die to match the original older tie rod - cost for die about 30+ bucks plus the cost of the newer style tie rods , OR - drumroll please - 3: you can re-use the steering linkage from the donor truck, drill two new holes to mount the idler arm to the frame and bolt the whole assembley into your truck! I did this since the steering linkage in the donor truck had been recently replaced and it is MUCH beefier than the original 1966 parts. It will bolt to the existing pitman arm. Once completed you will need to have the alignment re-done. (thanks wild one) 1963-1966/6 lug Crossmember Swap: '73-'87 front cross member bolts in with drilling/elongating a few holes (will require an after market 6 lug spindle) The V8 and the I-6 (except the 292) perches are the same for these model years so it will bolt right up. (verification needed) If you have changed out your front end to a newer '73-'87 setup and want to keep the 6-lug style you can purchase the $89 ea. 6-lug rotors through ECE part #03-6370-6L - 60'-70' c-10 6-lug (1 1/4" thick) (thanks custom63) Parts Swap: From '73-'87 you can unbolt the upper and lower control arms with the spindles attached and bolt these pieces onto your existing cross member. (clarification needed on 5-6 lug) OR You can re-use your existing upper and lower control arms and replace the upper and lower ball joints with new pieces from the '73-'87 donor truck. (clarification needed on 5-6 lug) Now, the steering linkage is slightly different for the 1966 to 1973/1987 models ( specifically the tie rod diameters ). There are a few different ways one can approach this situation, 1: purchase the adapter sleeve that mates your original inner tie rod to the later model outer tie rod - cost for adapters about 50 bucks , 2: remove the threads from the larger, newer model tie rod and retap the tie rod with a left hand die to match the original older tie rod - cost for die about 30+ bucks plus the cost of the newer style tie rods , OR - drumroll please - 3: you can re-use the steering linkage from the donor truck, drill two new holes to mount the idler arm to the frame and bolt the whole assembley into your truck! I did this since the steering linkage in the donor truck had been recently replaced and it is MUCH beefier than the original 1966 parts. It will bolt to the existing pitman arm. Once completed you will need to have the alignment re-done. (thanks wild one) Option 1: You need 73-87 3/4-1 ton lower control arms to do a 6 lug disc brake swap with stock 88-98 truck parts. (needs to be verified) Option 2: (done by dream68) The '88 spindle, rotor, calipers, and ball joints were used in the swap, but you need a 3/4 ton '68(other years see below) a-arm instead of the 1/2 ton one. The bottom '88 balljoint fits into the '68 a-arm, and the top '88 ball joint fits on the '68 a-arm. The top '88 ball joint you half to grind the rivets off of the 88 a-arm and then bolt it to the '68 a-arm. For steering linkage keep the 1968 1/2 ton intermediate shaft, 1988 1/2 ton tie rods, with the inner tie rod end changed to part#: MOOG ES2020. (done by dream68 on a '68 but should work on these years as well) I used a 1990 chevy front end/parts that had 5 lug 1.25" thick rotors and went to AutoZone and bought new factory 6 lug 1.25" thick rotors and bolted them on. (thanks firstgen) Potentially the following spindles, rotors, caliper and ball joints can be used (thanks jjr) CHEVROLET PICKUP TRUCK 88 2500 Series; 4x2 CHEVROLET PICKUP TRUCK 88-91 1500 Series; 4x2, 1-1/4" thick rotor CHEVROLET PICKUP TRUCK 89-91 2500 Series; VIN models "C/K", 4x2, 6 bolt wheel CHEVROLET PICKUP TRUCK 92-98 1500 Series; 4x2 CHEVROLET PICKUP TRUCK 92-98 2500 Series; 4x2, 6 bolt wheel CHEVROLET PICKUP TRUCK 99 1500 Series; exc. Silverado; 4x2 CHEVROLET VAN 96-99 1500 Series CHEVROLET VAN 96-99 2500 Series; 7300 lb. GVW GMC PICKUP TRUCK 88 2500 Series; VIN models "C/K", 4x2 GMC PICKUP TRUCK 88-91 1500 Series; 4x2, 1-1/4" thick rotor GMC PICKUP TRUCK 89-91 2500 Series; VIN models "C/K", 4x2, 6 bolt wheel GMC PICKUP TRUCK 92-98 1500 Series; 4x2 GMC PICKUP TRUCK 92-98 2500 Series; 4x2, 6 bolt wheel GMC PICKUP TRUCK 99 1500 Series; old style (flat, pull-up outside door handle), 4x2 GMC VAN 96-99 1500 Series GMC VAN 96-99 2500 Series; 7300 lb. GVW SUBURBAN 92 1500 Series; 4x2 SUBURBAN 93-96 1500 Series; 4x2, vacuum brake booster SUBURBAN 97-99 1500 Series; 4x2, gas TAHOE/YUKON 95-99 4x2 Potentially the following low control arms may work (thanks jjr) For lower control arm: the 67-70 3/4 lower arm can come from the following: CHEVROLET FORWARD CONTROL 68-70 20 Series CHEVROLET FORWARD CONTROL 68-70 30 Series; 7200 lb. rear axle CHEVROLET PICKUP TRUCK 67-70 20 Series CHEVROLET PICKUP TRUCK 67-70 30 Series; 7200 lb. rear axle CHEVROLET VAN 71 30 Series; drum brake GMC FORWARD CONTROL 68-70 2500 Series GMC FORWARD CONTROL 68-70 3500 Series; 7200 lb. rear axle GMC PICKUP TRUCK 67-70 2500 Series GMC PICKUP TRUCK 67-70 3500 Series; 7200 lb. rear axle GMC VAN 71 3500 Series; drum brake SUBURBAN 67-70 20 Series SUBURBAN 67-70 2500 Series If the 71-up 3/4 ton lower control arm can work they can come from the following: CHEVROLET FORWARD CONTROL 71-72 30 Series; 7200 lb. rear axle CHEVROLET FORWARD CONTROL 71-89 20 Series CHEVROLET FORWARD CONTROL 73-78 30 Series; non-removable carrier CHEVROLET FORWARD CONTROL 79-84 30 Series; drum rear brakes, sgl. rear wheels CHEVROLET FORWARD CONTROL 85-92 30 Series; exc. hvy. duty front susp.; drum rear brakes, sgl. rear wheels CHEVROLET FORWARD CONTROL 93 30 Series; exc. hvy. duty front susp.; drum rear brakes, sgl. rear wheels, w/o 9L6 brakes CHEVROLET PICKUP TRUCK 71-72 30 Series; 7200 lb. rear axle CHEVROLET PICKUP TRUCK 71-88 20 Series CHEVROLET PICKUP TRUCK 73-80 30 Series CHEVROLET PICKUP TRUCK 81-88 30 Series; std. duty susp. CHEVROLET PICKUP TRUCK 89-91 2500 Series; VIN models "R/V" CHEVROLET PICKUP TRUCK 89-91 3500 Series; VIN models "R/V", std. duty susp. CHEVROLET VAN 72-78 30 Series GMC FORWARD CONTROL 71-72 3500 Series; 7200 lb. rear axle GMC FORWARD CONTROL 71-89 2500 Series GMC FORWARD CONTROL 73-78 3500 Series; non-removable carrier GMC FORWARD CONTROL 79-84 3500 Series; drum rear brakes, sgl. rear wheels GMC FORWARD CONTROL 85-92 3500 Series; exc. hvy. duty front susp.; drum rear brakes, sgl. rear wheels GMC FORWARD CONTROL 93 3500 Series; exc. hvy. duty front susp.; drum rear brakes, sgl. rear wheels, w/o 9L6 brakes GMC PICKUP TRUCK 71-72 3500 Series; 7200 lb. rear axle GMC PICKUP TRUCK 71-87 2500 Series GMC PICKUP TRUCK 73-80 3500 Series GMC PICKUP TRUCK 81-87 3500 Series; std. duty susp. GMC PICKUP TRUCK 88-91 3500 Series; VIN models "R/V", std. duty susp. GMC VAN 72-78 3500 Series SUBURBAN 71-88 20 Series SUBURBAN 71-91 2500 Series NOTE: The steer stops are different on the older arms(same deal as the 1/2 tons, it will shorten the turning radius), & will require a little grinding on the stops on the spindles to straighten it up. (thanks crazy longhorn) Option 2: (done by firstgen) I used a 1990 chevy front end/parts that had 5 lug 1.25" thick rotors and went to AutoZone and bought new factory 6 lug 1.25" thick rotors and bolted them on. (thanks firstgen) Basically these are the parts I used: 1968 C20 lower control arms 1990 3/4 ton Light Duty 2X4 must have (1.25" rotors) spindles 1990 1.25" thick 6 lug rotors 1990 calipers off same truck 1990 upper and lower ball joints 1990 outer tie rods inner tie rods MOOG part #ES2020RL 1990 style tie rod coupler The only catch is to cut 3/4" off each end of both tie rods on each side of the truck so you can have enough room to align the truck. Well at least I had to since mine is lowered 4" in the front. The front end I bought off the 1990 truck was 5 lug. All I did was went and bought the 6 lug rotors and bolted them on. If you wanted to stay with the 5 lug, you'd save yourself about $120 bucks. After everything is done, you will now have 14mm studs on the front. I fixed this by drilling my rear axles and pressing in 14mm studs in the rear also but you wouldn't have to do this... I plan on going to a rear disc setup using a floating rotor design and so this helps that plan also... I used the rubber lines off the 1990 truck and used the factory mount from the 1990 to secure the line to the frame. Option 2: (done by captainfab) Spindles from any '88-'98 1/2 ton or light 3/4 ton 2wd pickup or suburban. Rotors from a 7200# GVW 3/4ton from '88-'98 (for some reason there is one part # for '88 & '89 and another for '90-'94. There are only minor differences between the two) I bought the one for the '90-'94 which is Raybestos #56915RGS. The ball joints you need to use are the ones for the '88-'98 spindles. The uppers will fit '63-'87 1/2 ton upper a-arms. The lowers will fit '69-'87 3/4 ton lower a-arms. The '69-'72 are prefered because of the shorter bump stop bracket. The newer ones could be easily modified. For steering you will need to use the '88-'98 outter tierod ends and the adjuster sleeves with ES2020L (ES2020RL?) inner tierod ends to mate up with the drag link. The calipers to use are the '88-'98 ones. Other than some minor things and replacement parts like bearings and seals, etc, I think that's about it.
1964 Fleetside LWB 1995 Yellow Mustang convertible 1996 Camaro Z28 My build thread Looking for help on completing the Disc Brake Upgrade Reference Thread If you didn't build it, you don't really own it Last edited by 1964C10; 10-30-2009 at 12:06 PM. |
10-15-2009, 03:40 AM | #2 |
Re: Disc Brake Upgrade Reference Thread
Can anyone tell me if the motor mounts for a V8 and I6 mount differently on the frame rail/cross member as it pertains to the disc brake setup? For example if I have an I6 and I bought the crossmember from a '78 V8 will I need to do anything differently to the motor mounts? or is it simple drilling/enlarging holes?
1964 Fleetside LWB 1995 Yellow Mustang convertible 1996 Camaro Z28 My build thread Looking for help on completing the Disc Brake Upgrade Reference Thread If you didn't build it, you don't really own it |
11-08-2009, 11:38 PM | #3 | |
ron |
10-15-2009, 04:41 AM | #4 |
If only rep was still here Id be sending it your way.
10-15-2009, 07:09 AM | #5 |
Hollister, CA.
((((Option 2: (done by captainfab)
Spindles from any '88-'98 1/2 ton or light 3/4 ton 2wd pickup or suburban. Rotors from a 7200# GVW 3/4ton from '88-'98 (for some reason there is one part # for '88 & '89 and another for '90-'94. There are only minor differences between the two) I bought the one for the '90-'94 which is Raybestos #56915RGS. The ball joints you need to use are the ones for the '88-'98 spindles. The uppers will fit '63-'87 1/2 ton upper a-arms. The lowers will fit '69-'87 3/4 ton lower a-arms. The '69-'72 are prefered because of the shorter bump stop bracket. The newer ones could be easily modified. For steering you will need to use the '88-'98 outter tierod ends and the adjuster sleeves with ES2020L (ES2020RL?) inner tierod ends to mate up with the drag link. The calipers to use are the '88-'98 ones. Other than some minor things and replacement parts like bearings and seals, etc, I think that's about it.))))))) Dude...great write up !!! With this option, are we still using the stock 63-66 draglink ?
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 10-15-2009 at 07:10 AM. |
10-15-2009, 10:05 AM | #6 |
John, looking at this:
Option 2: (done by dream68) The '88 spindle, rotor, calipers, and ball joints were used in the swap, but you need a 3/4 ton '68(For other year options see above in section 1963-1966/6 lug/V8) a-arm instead of the 1/2 ton one. The bottom '88 balljoint fits into the '68 a-arm, and the top '88 ball joint fits on the '68 a-arm. The top '88 ball joint you half to grind the rivets off of the 88 a-arm and then bolt it to the '68 a-arm. For steering linkage keep the 1968 1/2 ton intermediate shaft, 1988 1/2 ton tie rods, with the inner tie rod end changed to part#: MOOG ES2020. (done by dream68 on a '68 but should work on these years as well). I think that answers your question(?)
10-15-2009, 06:49 PM | #7 |
1 thing at a time is progress.
This is a great resource for those contemplating the swap. Great job. I used the 72 because I got the rolling frame with steering gearbox for $200. I could see how the brake lines were routed on the 72 so I could modify the 65 frame to accomendate the 72 lines. The only change I made was the rear crossmember where the line connects to the rearend brake hose.
Alan
Philippians 2:14-16 |
10-15-2009, 09:37 PM | #8 |
Thanks Alan! I know it's incomplete but hopefully with knowledge from others, I can "weld up" the holes so to speak.
11-05-2009, 02:32 PM | #9 |
hello, would 1963-1966 instruction work on a 69 c10?
11-06-2009, 01:26 AM | #10 |
60-66 Nut
Yes it will work all the way up to '70
11-08-2009, 11:17 AM | #11 |
Sounds like I can do this, but I do have a couple of questions. Will drop spindles for a '66 work or do I need the ones from the year of the donor truck? Also what may I run into with a 292 six? Really neat to see all this in one place, thanks.
Taclem |
11-08-2009, 11:30 AM | #12 |
Happy to be here
This is awesome information. Thanks for taking the time to put it together. I added this to our Suspension- Quick-FAQ links. LINK
Unless I missed it, one thing I see that you might add is the year range on 73-87 donors. For those that are not aware the Suburbans from '73 thru '91 use the same suspension. In most cases the Burbs will come with a front sway bar as well.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-08-2009 at 11:35 AM. |
11-10-2009, 12:44 AM | #13 |
Thanks for the great info guys!! Bear with me for a little while I am going through the big D in my life and it's taking it's toll. I am good though! Life is good. I'll check and here in the next few days make these updates!
N2Trux thank you!! Rolling baby!!
11-10-2009, 01:07 AM | #14 |
60-66 Nut
Sorry to hear that.....hang in there it does get better
I'm still working on getting a parts list together for the 6 lug swap with factory parts.....just been busy but I'm close.
11-10-2009, 01:16 AM | #15 |
Senior Enthusiast
11-14-2009, 01:52 AM | #16 |
60-66 Nut
***************THIS CONVERSION IS NO LONGER RECOMMENDED UNTIL THE ALIGNMENT ISSUE CAN BE RESOLVED***************
OK I finally got around to compiling this. Here is a list of parts and part numbers for converting to 6 lug disc brakes using factory parts. There will likely be updates later to the applications and years, as this here is just what I can confirm at this time. You will need the following parts from a '88-'98 C1500 or 7200#GVW C2500 pickup or Suburban, or from a Express or Savanah Van thru 2002 in a 1500 or 7200#GVW 2500 model. Spindles (unless you want dropped spindles) Rotors (if you find a 7200# GVW 2500 series) Calipers Front caliper hoses Outer tie rods Tie rod adjusting sleeve Lower control arm from a C20 (the '67-'72 have shorter bumpstop brackets. The '73-'87's will work, but may need to modify bumpstop bracket depending on rideheight) Don't forget all the little parts like, spindle nuts and washers, dust caps, nuts, bolts, washers, etc. The following are part numbers for new or rebuilt parts that can be sourced from your local auto parts store. Some of these are duplicates of the above in case you need new parts instead of good used ones. These part numbers I found online at CSK/O'Reilleys website. I looked these parts up for a '90 C2500 7200#GVW pickup. Rotors Raybestos 56915RGS Outer Bearing CR bearing BR3 Inner Bearing CR bearing BR5 Inner Seal CR seal 19984 Inner Tie Rod McQuay-Norris ES2020L Outer Tie Rod McQuay-Norris ES2836RL Tie Rod Adjusting Sleeve McQuay-Norris ES2004S Unloaded Calipers Cardone 184299 (R) Cardone 184300 (L) Loaded Calipers Cardone 154299 (R) Cardone 154300 (L) Semi-Metalic brake pads Brake Best MKD369 (cheapest) Brake Best SM369 (next best) There are many brake pads to choose from. It just depends what you want performance wise and budget wise. Front Hoses Brake Best BH177760 (L) Brake Best BH177761 (R) Raybestos BH38620 (L) Raybestos BH38621 (R) Upper Ball Joint McQuay-Norris FA1616 Moog K6292 Lower Ball Joint McQuay-Norris FA1617 Moog K6293 I think that about covers it. If you find any errors, let me know and I'll correct it in this post. If you have anything to add, post up.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 11-02-2014 at 01:18 AM. |
11-14-2009, 09:36 AM | #17 |
Senior Car Nut
Saved to favorites AND printed out. Thanks, guys, for taking the time to make life so much easier for the rest of us.
Larry |
11-20-2009, 12:23 AM | #18 |
thanks Captainfab for sharing that i was trying to figure out how to do this,what about Brake Booster and Master Cylinder?would this one work
http://shop.oreillyauto.com/productd...pe=250&PTSet=A |
05-20-2010, 07:34 PM | #19 | |
Thanks! Chris |
05-21-2010, 12:30 AM | #20 |
60-66 Nut
That is correct the '71-'87 C10's were not available from the factory with 6 lugs. If you want 6 lugs and disc brakes, you can either do the conversion with the '88-'98 OEM parts, or you can buy aftermarket 6 lug rotors for the '71-'87 spindles from suppliers such as CPP, ECE, etc.
08-14-2010, 11:18 PM | #21 | ||
60-66 Nut
IMO this would be the most cost effective way for you to get 6 lug front disc brakes. It should be a fairly complete list of parts needed. You should be able to use your C20 lower control arms since the '67-'72's mount differently.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-14-2010 at 11:19 PM. |
06-08-2014, 01:22 PM | #22 |
Nevermind.... This thread has changed since the last time I was on here my question was answered already.
James
'64 C10 Build Officially LQ/NV3500 swapped and Bagged Last edited by TypeSL2; 06-08-2014 at 01:32 PM. |
12-15-2009, 02:14 AM | #23 |
Damage Inc
Had a couple questions. I recently did a front disk brake conversion on my 68. They guy claimed it came off a 72 swb. The rotors are 1 1/4. A buddy of mine has a 72 with 1in rotors. The reason i ask is i want to install some drilled and slotted rotors but they are 1in. Would i have to get a different year rotor or change the caliper to fit 1in rotors. Any help would be appreciated.
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold 01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame 04 RCSB-joe gibbs clone,22in billets 68 stepper build http://67-72chevytrucks.com/vboard/s...d.php?t=332337 |
12-15-2009, 02:26 AM | #24 | |
60-66 Nut
The spindle is different from the 1" rotors to the 1 1/4" rotors.
12-25-2009, 04:22 PM | #25 | |
67-72 parts collector,…
Just curious about the drilled and slotted 1" rotors since I'm looking for a set. Do you know what brand they are or if they are for sale? (If you don't use them) The 1" rotors are "light duty" rotors that GM put on most of their 305 powered trucks in the early 80's. I never have figured our the exact combo that made GM decide which rotors they put on which trucks. |
