Mean Green
New rubber Whats next?
Hello brothers & sisters.
I received my new 28x14.5 QTP today along with the long length kicked out pan-hard bar to clear aftermarket diff cover. Marv has been such help with his advice on the wider tire and lower launch RPM to better my 60 & to make it more consistent. I have also read up on everyone's input on the 3" exhaust. I have the 1 3/4" hooker super comps with 3" collector. I'm currently running 2 1/2" w/ X-pipe and delta flows. The new pan-hard bar is going to hit the exhaust so its time to run 3" since my 406 put up low lower 600hp. My question is should I run another x-pipe system and what types of mufflers are out there to run besides flow-masters? Thanks for your input in advance.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
Re: New rubber Whats next?
I hear Dynomax Ultra-Flo's are good race mufflers...not the bullet ones, but the oval ones. I'm gonna try the bullets on mine though.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
X or H-pipe if you are looking for every little bit and a straight thru muffler is your best bet.
Depending on how loud you want it at idle would really depend on what muffler you want. The Magnaflows are quietest at idle and the Dynomax will be about the same sound level as the flowmasters.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
Borla xr-1 mufflers are real good i love mine. i have a question 68 C-10 where did you get the long length kicked out pan-hard bar to clear aftermarket diff cover. my pan-hard bar is hitting my cover now. im wanting to run a aftermarket diff cover but cant.
Brandon Street Car Mafia |
#5 | |
Mean Green
I bought the bar @ CCP. Looks to be a nice built piece.
Mean Green
Thanks for the info on mufflers and X pipes. I didn't know that they make ones with cut outs now. Yes I'm going with a X-pipe system.
I would like to go out side of the box and run something different. Those Borla's sound tough guy. Any one have info on spin tech? I also need to figure out were to dump the exhaust out at. I currently runs straight out the back, I was thinking dump them down at the corners kinda like the GTO's I ordered a new go fast goodie today. A system one oil filter.
I have the Pypes Violators in 3in and LOVE it. Sound is just nasty. I would dump the exhaust before the rear axle or out before the rear tires.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
Thanks for info.
motor exploder
Spintechs sound pretty cool, but for max power, I would run a straight through muffler like the Pypes or Dynomax Ultra Flows. They will flow the best since there's nothing in the muffler to slow the exhaust gas down. Borla's are really nice too if you have the money.
ECE also carries the track bar with the bend in it to clear the rear diff.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
no i havent thought bout that thanks
If you like them, let me know, I am a dealer and if we want to do a GP or something like that I am here to help!!
motor exploder
I've heard a lot of good things about the Pypes mufflers, they offer a 3" X-pipe also. From what's on their website, their stuff sounds awesome. I would run an X if I were you, Flowtech has one with cutouts built into it, and Jeg's has one too, but the cutouts are in front of the 'X'. The Flowtech piece has the cutouts after it.
k thanks ill look at them
#15 |
i prefure Dynatech oval case mufflers.
#16 |
Mean Green
Dang so many options to choose from. I see a lot of the dragsters and tube chassis cars running the Borla's. I will look into the Dynatech and the Pypes.
ripdog28 I might try to run the exhaust a little longer than that. I drive this thing all over town and to shows in the summer and the big track is 40 miles one way, so I will try to keep cab noise down a little.
#17 |
I was running a 3" X-pipe with Warlocks (uncorkable) for a while. Loved the system. I switched to a dual 3" electric cut outs hanging right off the header. Then to the muffler it necks down to a 2.5" turbo muffler to quiet it down..
The warlocks were nice for being able to uncork it at the track..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#18 |
![]() Join Date: Jan 2008
I run a 3" mandrel bent system with the x-pipe just behind the trans, with Dynomax Super Turbos.It dumps right behind the rearend. It has a real nice sound , not loud or cackly,and seems to make real power. Good luck
#19 |
Mean Green
I bought the Borla xr-1's. Installed the new Panhard-bar and have the new 28x14.5's on.
I'm going to run the the truck with the new tires before I Do the 3" exhaust swap & the one piece drive line change out.
#20 |
The new rubber looks good.
#21 |
What style of tires are those?
#22 |
Mean Green
Those are the Hoosier quick time pro's. They are a bias tire that is a tube type.
They are the widest short tire I could find besides the M/T drag radials.
#23 |
you will like those meats. same ones that i run. wish my rims were a 12" tho..
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
#24 | |
Mean Green
That's kinda my same thought. I think the 12" would help keep the tire a little more square. If I did my measurements right I need like a 7 1/4"-1/2" BS.
#25 |
Sunburst C10!!!
Just an FYI here
i have dynomax bullets and they sound like crap
Gage 1967 C10 Shortbed Stepside |
