Difference in NP241?
I'm wondering if there is a difference between an NP241 mated to a 700R4 and an NP241 mated to a TH400. The tag on says NP241 C and both are passenger side drop. The listing says the case was pulled out of a 1990 Suburban 3/4 Ton with a TH400. I have an 89 K5 Blazer with a 700R4. Unfortunately I don't know the differences between transfer cases. Thanks in advance.
Re: Difference in NP241?
To my knowledge there's really no big difference (?) I have a 700R4 backed by a NP241C.
86 Suburban 2WD = rolled it and totaled it ![]() 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. ![]() 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
Slots go on anything!
The NP241 is very similar to the 208, but has a VSS instead of a Speedometer cable. There may be other differences, but that is the main one. 90-91 4wd trucks have an electronic cluster instead of a cable driven one.
1974 Jimmy- 5.3/4L80e/NP241 |
from what i read the spline count on the 700r4 and 350 is 27 and on the 400 and manual trans is 32
1987 Buick Grand National 2018 Road Glide Special |
Yes. The spline counts are different. I was looking for an np241 for my project last year and they are kind of hard to find. I think they only came in 89' to 91' Blazers and Suburbans.
Posted via Mobile Device |
I put a np241 from a 91 burb behind my th400 and had to change the inputs. 27 on the 700r4 and 32 on the th400.
Real Projects never die
oh ya, because your trucks an 89 the 90 t case would bolt in, you could swap to the vss style speedo, but if you put the 90 case in you'll lose the speedometer without changing anything else. Whats wrong with your current case?
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
Also, the 1990-1991 np241 has a vss output rather than a mechanical speedo output like the 1989 np241 had, but other than that i believe the only difference is the 27 spline input for the 700r4 version and the 32 spline for the th400 or sm465 version (I believe)
