07-20-2010, 09:59 AM | #1 |
Coolant line through throttle body
How are you eliminating it?
I've been told you can't just cap the line and you need to bypass the throttle body and plumb it in somewhere else. Let me know what you're all doing. Thanks |
07-20-2010, 10:44 AM | #2 |
Next project: 1970 K10
Re: Coolant line through throttle body
A hose barb. Clamp, then disconnect the hoses from each side, then connect together with a hose barb and clamps. You don't have to bypass the TB though. It is suppose to help with cold starts by heating the incoming air. How much good it does or not, or how much power is gained by eliminating the heat, I don't know. Mine is still hooked up, although I will probably do away with it and completely grind the fittings off of the TB some day.
That of course would be on an OEM type set-up. For a conversion, you can do a few different things. Starting a the steam pipe on the drivers head, you can just forget running it to the TB altogether an either 1] drill and tap the top of the water pump and run the hose there, 2] run the line to the radiator if yours has a nipple for a heater hose (most 67-72's and 73-91's did), or 3] use an adapter from Jags That Run and tie it in to the upper rad hose. Tapping the water pump is the shortest and cleanest way to do it. I did mine like #2. #1 #2 (right above MAF) #3
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-20-2010 at 10:57 AM. |
07-20-2010, 11:15 AM | #3 |
Yeah, I bought an Entropy aluminum rad. before deciding to do an LS engine, so I ordered without any heater returns. They also could have sent me one with the upper hose switched to the pass. side to avoid the big snake of a hose, but hind-sight is always 20-20...
I like #1, but my water pump is already mounted and ready to go. It probably wouldn't be a good idea to drill/tap it with it already mounted in place, so the #3 is probably what I'll do -- Thanks for your detailed description! - |
07-20-2010, 11:31 AM | #4 |
Future TOTM Winner
I've been reading up on this too. Just so I'm clear, the steam is running FROM the head TO the throttle body/water pump/radiator, etc. right? I'm just trying to understand these engines top to bottom, front to back...it isn't easy.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
07-20-2010, 11:36 AM | #5 |
Correct. This line is there to prevent air from becoming trapped in the highest part of the engine with no where to go, hence the term "steam line".
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-20-2010 at 11:36 AM. |
07-20-2010, 11:34 AM | #6 |
If you are careful, you can drill it in place. Slop your drill bit, and the tap, in wheel bearing grease before starting. The grease will hold all the chips and prevent them from falling into the pump. And, with the o-ring sealing gasket, you are pretty safe to pull the pump to drill it on the bench if you want to. Mine has been off 3 or 4 times using the same original seal set, no leaks.
I like details. They say man is a very visual creature!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
07-20-2010, 11:36 AM | #7 |
Ok, so how about this: (it would send it into the heater hose...)
http://www.dormanproducts.com/p-26166-47112.aspx Decisions, decisions... |
07-20-2010, 12:06 PM | #8 |
Off the top of my head, I don't see why not. I would probably want to run it as high as possible in the system though, which would put it up near the firewall.
07-20-2010, 12:12 PM | #9 |
gets board easy.......
thats good to know, i tried by passing on one of my toyotas and the throttle boddy needed the heat
07-20-2010, 12:22 PM | #10 |
I have bypassed on a couple other 5.3 and a 6.0 trucks that I've had before with no issues, so it can be done to these engines. They don't necessarily rely on the heat.
07-20-2010, 05:47 PM | #11 |
My steam line didn't go to the throttle body (2005 LS2). The Chevy book on LS swaps says the line should go to the highest point in the coolant system. I drilled a hole in the radiator and used an AN bulkhead fitting and a washer with an o-ring molded into it to attach the line.
It is interesting that with the line that way I could completely fill the radiator on the initial fill. Air kept bubbling out of that fitting in the radiator until the engine was full. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
07-26-2010, 11:25 PM | #12 | |
GM ONLY BABY!!!
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
07-20-2010, 06:00 PM | #13 |
Thanks for all the options. Keep it high! --
07-25-2010, 10:20 PM | #14 |
GM ONLY BABY!!!
Is this absolutely necessary? I have a 01 6.0 LQ4.
07-26-2010, 09:10 AM | #15 |
To run it through the throttle body? No.
To run it back into a high part of the cooling system? Absolutely.
07-26-2010, 07:18 PM | #16 |
I JB welded a ribbed tubing fitting into one of those heater hose flush and fill Tee screw on caps and put it in my heater hose. Over 2 years and no problems. Cheap temporary fix that I forgot to replace.
07-27-2010, 09:32 AM | #17 |
My 07 4.8 has it going strait to where the old school heater hose dump is in side of the rad tank. I guess if coolant circulates threw it it is ok. Cause that is not the hightest place by far.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
07-27-2010, 10:29 AM | #18 | |
I think the TBSS has the steam hose running to a "T" into one of the heater hoses. One thing that will alleviate any problems is to jack up the front of the truck while filing the cooling system to help prevent any air pockets from forming during filling.
07-27-2010, 12:29 PM | #19 |
Truck and auto performance nut
I'll try to remember and check ours tonight...
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
07-25-2010, 11:25 PM | #20 |
I believe so
07-26-2010, 11:42 PM | #21 |
GM ONLY BABY!!!
never mind, googled it and found it.
