04-08-2011, 10:06 AM | #1 |
Wiring Issues
So i got my truck back from the shop yesterday. its a 1994 chevy extended cab stepside. 5.7. I need to know where all the grounds and tail light wires are. MY problem is that all the taillights are plugged in and none of them work. If anyone had a diaghram to help me out it would be greatly appreciated. I just need to know where to start looking. Thank You in Advance.
04-08-2011, 11:32 PM | #2 |
One day...
Re: Wiring Issues
Raise the hood and on the lower right side (drivers) there will be a bulk head of wires and i believe the lowest on on the right is the harness for the tail lights. Crawl under the truck and find the loom going to the tails and make sure which connector it is.
Ill start with a simple ? you did check the fuses, right? Do the dash lights work ok? Last edited by scotts62; 04-08-2011 at 11:33 PM. Reason: added |
04-09-2011, 07:58 AM | #3 |
Re: Wiring Issues
Checked the fuses. All of them are good. Headlights work. Dash lights dont. Horn doesnt. I think i have a ground not hooked up. I was just trying to get some information before my brother came over to help me figure it out. Ill Keep looking. Thanks Guys.
04-09-2011, 09:51 AM | #4 |
Re: Wiring Issues
So theres a little tan/white wire running parallel with the tailight wires from the engine compartment to the back. What is this for?
04-09-2011, 10:30 AM | #5 |
One day...
Re: Wiring Issues
Not sure. Are the wires good in the loom to the back?
04-09-2011, 10:42 AM | #6 |
Re: Wiring Issues
no there all pulled out in the back.. i think ineed to start connecting them with new connectors. which one is the ground? The wireing on this truck is so screwed up. It was wrecked three times by po's. Thank you scotts for atleast hearing me out and helping me with this one.
04-09-2011, 03:43 PM | #7 | |
Re: Wiring Issues
Is your truck a mix of parts from other models years?
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. Last edited by ChevyTech; 04-09-2011 at 03:46 PM. Reason: spelling |
04-09-2011, 03:52 PM | #8 | |
Re: Wiring Issues
You might not be able to unplug the headlight switch if it is melted to the connector. Do the rear turn signals work?
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
04-09-2011, 06:49 PM | #9 |
Re: Wiring Issues
i did some more digging around. Connected stuff and still nothing... My bed is off a different struck but same year. My fuel pump/sending unit works just fine. I dont know what else to do.
04-09-2011, 06:57 PM | #10 |
Re: Wiring Issues
did you replace the "circuit board" in the tailight housing? those are known for going bad also
04-09-2011, 07:01 PM | #11 |
Re: Wiring Issues
yepp brand new circuit boards and bulbs..
04-10-2011, 08:20 AM | #12 |
laying low
Re: Wiring Issues
I'd start at the rear. Test for power to the taillamps. Work your way back to the front from there.
04-11-2011, 12:11 AM | #13 |
Ignorance is Bliss
Re: Wiring Issues
Ground wire should be black, back by the bumper, but underneath the truck, the ground should connect to the bottom of the bed. I pulled my box to get to the fuel pump and missed that wire, yanked it out without knowing. Screwed up my lights for a day while I tracked it down.
Frustraiting to say the least.
The difference between ignorance and stupidity: Being ignorant you just don't know any better. I must be stupid, because I know better and do things anyway. 98 GMC Sierra 1500 4x4 xcab 3door, 350 Vortec, 6" lift, 35" M/S Tires and no money in my wallet. 90 GMC Suburban 1500 XLE 4x4 with those darned barn doors (I cried when she left me) If the women don't find you handsome, they should at least find you handy. |
04-12-2011, 09:09 AM | #14 |
Re: Wiring Issues
So heres a new problem. Got power to the tailights. No brake lights. Only one reverse light works and the parking lights are top and bottom now. Im so ready to get rid of this truck. Could it be the brake switch connected to the pedal?
04-12-2011, 10:11 PM | #15 | |
Got dropped
Re: Wiring Issues
the park lights should be on the top and bottom only the brake light, lights on the bottom.
93 Chevy C1500 Sport 4/6 Drop, Black and Red Int. 00 K1500 ECSB Z71 Stock Daily Driver w/18" Z71 Wheels |
04-12-2011, 10:51 PM | #16 |
Re: Wiring Issues
i had the same problem on my 94 gmc the headlights works and nothing else it happened twice the first time was the switch itself and the second was a wire was rubbing against the frame in the back and wore through so id look for bad wires or a bad switch
IM ONLY 18 AND LOVIN IT IF MUD AINT FLYIN YOU AINT TRYIN! 1badgmc- Just think. Someone worked hard to make it look that bad. 1988 chevy stepside 305 five speed Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383945 1994 GMC ext. cab short box 350 auto Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438873 1996 GMC 2500 ECSB 454 4l80e: build thread http://www.gmt400.com/forum/showthre...gmc-2500-build 1998 GMC K-1500 ECSB 305 auto partd truck 1999 GMC K2500 suburban 350 4x4 Dads project 1981 Corvette 350 auto Also Dads project 1989 Corvette 350 auto ^^ 1998 GMC K1500 ecsb 305 auto Brothers project |
04-13-2011, 09:25 AM | #17 |
Re: Wiring Issues
