06-06-2013, 07:21 PM | #1 |
1985 Chevy c60 ramp truck with a 1970 454, early sm465, & 2 speed Rearend????
I have 1985 Chevy c60 ramp truck with a 1970 454, early sm465, & 2 speed Rearend. So can I change the Rearend gears so when in high I can go like 65 mph and get better mileage also I am trying to figure out how to get better. Mileage and highway speeds out of this big truck? Thank you in advance
Posted via Mobile Device |
06-06-2013, 08:40 PM | #2 |
Re: 1985 Chevy c60 ramp truck with a 1970 454, early sm465, & 2 speed Rearend????
Finding the higher gears would be the biggest problem. You might try calling a Chevy truck dealer to see if any are available, or if they were ever available.
If nothing works out for you, you could try taller tires, especially if you are running low profile tires now. Bill
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
06-06-2013, 08:47 PM | #3 |
This has 20 inch rims its a big tow truck this is one step down from a big rig basically I just wanted to know if I could leave low the way it is and change the high gears to something better for gas or like use the high as low and change the high to make it do way better on highway
06-06-2013, 09:00 PM | #4 |
Well, I would still check with your local dealer on the gear question.
The 20 Inch wheels are the norm on your truck, but what size tires are you running? And are you sure they aren't Low Profiles? Believe it or not, tire size can make a notice-able difference, and a cheaper way to boot.
06-06-2013, 09:23 PM | #5 |
No they are ply tires not radials
06-06-2013, 10:12 PM | #6 |
I'm not an expert on anything, much less the "heavies". But, if you already have the two speed rear I think you probably already have 6.40/8.72 ratios, which were pretty much standard. The low range is a planetary reduction of the high/direct range, not another gear set.
You might could find an axle out of a diesel truck with ratios like you like, given that a diesel rear will be designed for lower engine speeds. Or you could look at finding an overdrive five speed trans out of another big truck. You could also consider swapping out the thirsty BBC for a smaller 350 or something if you don't need all the power. You'll still be screaming along at 3,500+ going 65, but you should use less fuel doing so. Hope this helps. |
06-06-2013, 10:48 PM | #7 |
Why not go to a 5 speed od trans? Would be cheaper and easier probably
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD 73 k5 gm crate 350-265 / sm465 / np205 3.73 posi |
06-07-2013, 09:34 AM | #8 | |
06-07-2013, 12:45 PM | #9 |
Np540 would be, but how bout a nv4500, it would be strong enough, probably less effort than swapping gears in the rear,,,
06-08-2013, 05:21 PM | #10 | |
Hopefully it will clear up some info and I welcome anything that anyone can contribute as it is a subject that I am still very interested in. Also notice another poster also saying that the OD Trans is "hard to find". http://www.stovebolt.com/ubbthreads/...&Number=814855 Bill
06-07-2013, 08:02 AM | #11 |
does it have Budd wheels or Dayton wheels? and the reason I ask is if it has budds you can get the centers cut out and put into 22.5 wheels, then you have a large number of sizes to choose from, Might be some up front expense but would be worth it in the long run!
Disabled Vet, Desert Shield/Desert Storm Veteran "Proud to have served" 1965 C-10, 1965 C-60, 1966 C-10, 1975 C-20, 1986 M1009 Blazer, 1987 GMC 1/2 ton suburban, 1995 1500 Suburban 4x4, 2001 2500 Suburban 8.1L Last edited by alabama mike; 06-07-2013 at 08:10 AM. Reason: spelling |
06-08-2013, 06:14 PM | #12 |
Well i would rather not change tranny since i have put a lot of work into it and tbis in 4th is 1 to 1
06-09-2013, 02:21 PM | #13 |
I think the trans option would be the best route. Look at a Spicer 3053A (I think thats the right variant). They came mostly in military trucks. It might be the best option.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
