03-05-2014, 03:32 PM | #1 |
5.3 swap build so far
well i figured id go ahead and show my progress as of now, i got a 84 k10 dropping a 2004 5.3 with 4l60e and bolting up my 208 transfer case, Im waiting a buttload of parts to get in the mail, but here is a couple pics of what i got done so far
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
03-05-2014, 03:34 PM | #2 |
Re: 5.3 swap build so far
heres a few more, the truck when i first got it and then after i put a lift on it
03-05-2014, 03:36 PM | #3 |
i would love some advice on linkage and fuel delivery, with the fuel delivery i was going to get the fuel pump and sending unit out of a 2004 chevy truck and get the corvette fuel filter and mod my tank to take these any input? and as far as linkage I'm kinda lost
03-06-2014, 10:07 AM | #4 | |
For the linkage you should be able to use the factory parts with some slight modification. Once you get the engine in you can hold it in position and see how far off it is.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-06-2014, 08:17 AM | #5 |
any takers?
03-06-2014, 10:13 AM | #6 |
so with the walbro 255 it goes inside the tank?
03-06-2014, 10:25 AM | #7 |
Yes, if you get a tank and sender from an '87, they had in tank pumps, but were lower pressure so that's why you need a higher pressure pump.
03-06-2014, 10:32 AM | #8 |
gotcha...so in short I'm making this harder than it has to be
03-06-2014, 10:13 AM | #9 |
i havnt messed with fuel injection too much
03-06-2014, 11:12 AM | #10 |
is this the one i need? http://www.summitracing.com/interim/...ping#Estimator
03-06-2014, 11:30 AM | #11 |
Something closer to this. http://www.summitracing.com/parts/vp...58-2/overview/ Keep in mind the hose length/shape may differ since it's going in a truck sender.
This is the type of sender you would need. The actual one will depend on which side your tank is on and how big it is. http://www.rockauto.com/catalog/more...291&cc=1059825 This should fit your existing tank, but it won't be baffled, and without baffling, the engine could momentarily starve for fuel under certain conditions (hard cornering or acceleration) when the fuel level is low.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html Last edited by ls1nova71; 03-06-2014 at 11:42 AM. |
03-06-2014, 11:37 AM | #12 |
i used an ac delo pump Amazon.com: ACDelco EP381 Fuel Pump: Automotive
03-06-2014, 11:40 AM | #13 | |
03-06-2014, 11:39 AM | #14 |
ordered....it was the same one that i put up haha
03-06-2014, 11:41 AM | #15 |
that would have saved me some money tho
03-06-2014, 11:47 AM | #16 |
so what year corvette filter do i have to get now? i got the pump check, sending unit check, filter....not check
03-06-2014, 11:54 AM | #17 |
Get a Wix 33737. It's a 200 Vette filter. Any cheaper brand and it's a crap shoot if it will even work right out of the box. You DO have a returnless rail, right? 2004 you could get either depending on if it was flex fuel or not.
03-06-2014, 12:04 PM | #18 |
ill take a pic, but i don't think i do
03-06-2014, 12:08 PM | #19 |
If you don't have a returnless rail, then you don't need the Vette filter. A returnless rail will only have one line, a return style will have two, a 3/8 feed and a 5/16 return. The dead giveaway is a vacuum hose from the intake to the fuel pressure regulator on the rail.
03-06-2014, 12:10 PM | #20 |
Here's one
03-06-2014, 12:11 PM | #21 |
Another
03-06-2014, 12:12 PM | #22 |
And a third
03-06-2014, 12:17 PM | #23 |
A side shot would be easier to see it in, but that's a returnless rail. Get the Wix 33737.
03-07-2014, 06:45 PM | #24 |
What kind of motor mounts are you looking at?
03-22-2014, 01:02 PM | #25 |
after reading this post again, i just wanted to clear something up, i didn't get the mounts from trans adapt, i got them from summit, i did get my adapter from my 4l60 to my 208 from them, and those guys are awesome....everytime i had a question for them they was right there to help me....the motor mounts i got from summit...i didn't like them, they didn't line up right and i had to fab them up some.
