05-17-2014, 08:07 PM | #1 |
Turn Signal Issues and I'm frustrated.
Hey guys. My 79 Chevy is driving me nuts. Only the left rear blinker works. When I flip the turn signal lever to the left I can hear it clicking but, when I flip it to the right I get nothing. When I turn on the lights all the lights work. I checked all the bulbs front and rear. Replaced the flashers. Sockets are nice and snug. What am I missing here.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
05-17-2014, 08:29 PM | #2 |
Re: Turn Signal Issues and I'm frustrated.
It could be a failed turn signal switch.
You can unplug it at the long flat "harmonica" connector on the steering column under the dash for testing without having to tear the column apart. With the switch unplugged, you can use an ohmmeter to test for continuity between the various wires of the switch. In the "left turn" position, there should be continuity between the purple wire and the light blue wire. As well as continuity between the purple wire and the yellow wire. Similarly, in the "right turn" position there should be continuity between the purple, dark blue, and dark green wires. Also with the switch unplugged, you can temporarily install jumper wires on the truck half of the wiring connector to simulate the functions of the switch. That'll let you know if the problem is in the switch or somewhere else. Jumpering the purple wire to both the light blue & yellow wires should make the left turn signals flash. Similarly, jumpering the purple wire to both the dark blue & dark green wires should make the right turn signals flash. |
05-18-2014, 01:30 AM | #3 |
Try your four way flashers. See if they work. Then you know if it might be a bulb?
Then I would be checking all the grounds. Maybe put in extra grounds like box to frame, cab to frame, engine to frame, etc. they corrode and lead to all kinds of strange goings on electrically speaking |
05-18-2014, 03:07 AM | #4 |
At the body shop.
Mine did the same. Needed a turn signal switch.
" That didnt make it any newer " " Dont antique the equipment " |
05-20-2014, 05:43 AM | #5 |
4 way flashers do not work. Does anyone have a write up on the switch replacement. Just like to know what I'm getting into and any tips/tricks before diving in. I've done one a while back on a Chevelle with ignition in the dash. Never done one on something this new. I tried a search on the forum but, didn't really find a good write up.
05-20-2014, 06:46 AM | #6 | |
1982 chevy silverado It's all about original guys original let me say again original. |
05-22-2014, 04:30 PM | #7 |
Just replaced the turn signal switch. It was a pretty straight forward process. Unfortunately now I have nothing. No signals left or right. I'm positive I installed everything correctly. What am I missing here. Maybe a blown fuse during the process? I had the battery disconnected.
05-23-2014, 06:29 PM | #8 | |
If the fuse checks out okay, use the test light to check for power on the purple wire at the turn signal switch connector. Again, that should have power with the ignition switched on. That point in the circuit is after the flasher so depending on how much load your test light places on the circuit, it might be lit steady or it might blink when connected to the purple wire. Either one is fine. However, if you don't have power on the purple wire then there is something wrong with the flasher or wiring. The continuity tests I described check the turn signal switch itself. I assume you mean the switch tested okay? |
05-22-2014, 06:31 PM | #9 |
I have continuity testing the wires ray_mcavoy said to check.
05-23-2014, 07:36 PM | #10 |
Yes, I did the continuity testing on the switch itself and it came back ok. I took a picture of my fuse block. Most of the lettering is worn off and I do not see the fuse you're talking about.
05-23-2014, 07:56 PM | #11 |
Yeah, they can be hard to read when the lettering gets worn off. And those factory accessory wire plug-ins can make it hard to count the rows.
I believe this is the fuse ... I circled it on your pic: |
05-23-2014, 08:53 PM | #12 |
ray_mcavoy, thank you for keeping me motivated on this. I'm happy to report that I pulled that fuse to see if it was blown. It was not but, I swapped it out with another one anyway and bam! All four signals are working like a champ. I've owned several muscle cars and three 69-72's. This is my first square body but, I will say I've always had the weirdest gremlins with old GM trucks. Chevelles, Novas, Camaros are pretty straight forward but, these old trucks just need constant tinkering which is fine by me. They don't require a ton of money, I think they just enjoy your time spent with them. I hope someone searching the forum in the future finds this thread and it helps keep them motivated as I was about to just start using hand signals!
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins Last edited by HeloCrewChief; 05-23-2014 at 08:53 PM. Reason: update |
05-23-2014, 10:32 PM | #13 | ||
Reading back through this thread, it sure sounds like you had a weird combination of gremlins with this case ... The old turn signal switch was most likely causing the behavior you were seeing at first with only left rear signal working. But to have the fuse problem right after replacing the switch (causing all of the turn signals to quit working) was definitely a strange coincidence |
06-09-2014, 11:36 AM | #14 | |
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
05-23-2014, 10:05 PM | #15 |
That fuse has probably been in there 35 years. Could just have been oxidation on the fuse blades and/or the socket wipers. One thing you might do now that you have been into it and know how to contort yourself to get at it: pull out every fuse one at a time and then push it back in. You already know that the environmental conditions etc that the truck went through gave you bad contact on a good fuse, so why wait for the next gremlin? Head that bunch off at the pass!
And thanks for the follow-up. We all learn more every day, which makes it easier to help the next guy who has one he can't figure out.
Rich Weyand 1978 K10 RCSB DD. |
05-23-2014, 11:49 PM | #16 |
Thank you guys. Yeah, the other thing is trucks of this vintage have most likely never been restored, just "used". In any case I serviced/replaced things that need to be looked at after 35 years. FWIW the truck is in Washington state and is exposed to rain frequently which probably led to some electrical gremlins.
05-23-2014, 11:55 PM | #17 |
Here are a few pictures of her all lit up. Keeping all those lights working on this old beast is a job in and of itself.
06-08-2014, 03:06 AM | #18 |
I've had some issues with my '80 K20 since I've been starting to put it back together. I really suck at wiring and figuring out the issues but, I purchased a GM Service Manual off of Ebay. It's been a great tool and resource for me during my whole project. I think they are 10x the manual that Chilton's manuals are. He's a link check them out.
http://www.ebay.com/itm/1979-Chevrol...2403c0&vxp=mtr |
06-09-2014, 11:29 AM | #19 | |
Moderator
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
