![]() Join Date: Mar 2014
When to use front shock relocators?
I just got some 3 inch front drop springs for my 1970, to go with my 5 inch rear drop springs. I had to relocate the rear shocks - so my question is do I need to relocate my fronts? I can't find a definite answer on here, I have everything ready to install.
Is there a certain amount of drop with springs that you need relocators? Or will I be okay with stock location?
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
#2 | |
Re: When to use front shock relocators?
Measure a front shock installed w/full vehicle weight on the corners. Pull a front shock & measure the fully compressed + extended dimensions. The math will suggest what you should do.
Tags |
drop, relocators, shocks, springs, static |
