my twin turbo sleeper nova
here is the build up of my 64 4 door nova, a continuation of my previous thread
http://www.stevesnovasite.com/forums...d.php?t=220060 after driving this car all summer, going to the goodguys car show in texas, driving around town,and just simply enjoying it, its time for a little winter project here is what I have so far, some LS flanges and some pipe...the turbos are going to be 70mm units, and the end goal is going to be 1000HP..should be a fun little ride.. so here is what im starting out with... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 |
Re: my twin turbo sleeper nova
so, in starting to figure out where I can mount these, while retaining the stock hood, down bars, inner fenders, and even the current exhaust I have (3" magnaflow)... once I had it somewhat positioned, I removed the driver header, and begin to build the new header, starting with the flange, and some 1.75" primary tubes.... here is the progress so far...
dang brake lines are in the way, but there happened to be a tube that had most all the bends in the right spot to clear them, now only 3 more tubes needed to be fabbed on the driver side... so cut, index, mark, and weld was the process...
![]() Join Date: Jul 2012
This is cool and I am tagging along!
Right on! I love the sleeper vibe. Is it a 4 door?
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540 1992 Chevy K1500 Silverado ECSB 1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered |
Now a "really cool" "Ol grandma car" .
"I feel the need for speed!"... as soon as I am done with my nap. |
with all the pipes, in postion, I cut the tack welds at the flange, then fully welded all the pipes, then final welded them to the flange... once they were fully welded in, I clamped them using a big hose clamp, cut the primany tubes flush with each other, welded on the collector, then cut collector to length, and then welded on my 3" v-band...
so, you'll notice that the turbo is more forward then where I first had it positioned, this is because there wasn't enough room to run my 3" exhaust down pipe from the turbo to the exhaust...so forward it went, it still is going to be tight, but doable...also, the fuses/relays in the engine compartment will have to be relocated, cause the turbo inlet is trying to suck them in
![]() so ill have to move them to the inner fender area...but so far, so good, and the hood closes with no interference....
Wide n'Low
![]() Join Date: Jan 2007
Diggin it, nice work so far.. Following along, thankfully the son's truck has more under hood room to play with when he gets to his
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
blood type; Retumbo
it takes some real gumption to take a bite as big as that.
One thing I'm curious about though. Are the pipes close enough to the hood to hurt the paint?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
I too thought of that, as is, they are about 1" away, so ill run it, and check the temps on the hood, and if needed ill add some heat mat to the bottom of the hood.
Are you MIG welding all your hot and cold side piping? If so what kind of welder do you have and where are you getting your pipe from?
6>8 Plugless........
![]() Join Date: Sep 2007
Nice work and sweet Nova! Are the pieces that bolt the turbine housing, with the flange on it to connect to the header, cast aluminum?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#15 | |
the 90* v-band to T4 transitions are 304 Stainless Steel Cast
#16 |
pass side done. same routine as the driver side. position the turbo where it needs to go, then build the header to it... cut the pipes, clock them, mark them, then weld them...
#17 |
#18 |
Great work! I started putting twin turbos on my 40 Ford with a 354 Hemi in it. I feel your pain on the room issue.
#19 |
once headers were made, I looked into mounting my wastegates, I decided that mounting them inboard looked the best, and would keep my vacuum line routing shortest run possible, to aid in response.. I went with precisions 46mm wastegates.. here is some pics of mounting them...
#20 |
Nice work!
#21 |
once I had the wastegates mounted, my next step was to make the down pipes to connect to my existing exhaust. I made the down pipes to connect with the existing placement of the header collectors, so if I chose to, I can just put my headers back on, and not have to do anything to the exhaust.
the pass side wasn't to bad to make, as there wasn't much I had to clear. The driver side was a bit more challenging, as I had to snake around the steering shaft, and the header itself, but I got it. the down pipes are 3" mandrel exhaust. once I had the DPs made, I then mad the wastegates connection to them, and finally welded in my 02 bungs, 2 per side, 1 for my 02 sensors, and one for my wideband. here are a few build pics ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#22 |
![]() Join Date: Jun 2012
Ok, I'm watching! That sir, is some fine work. Awesome
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
#23 |
thank you
#24 |
so, with no time to spare, I tore it down, disassembled the turbos, and sent it all off to get ceramic coated.. here is some turbo tare down pics, and the pieces going out to get coated.
#25 |
Man of Mini-Talents
You got my Good Lord Award on this one.
Very cool.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
