07-04-2015, 03:59 PM | #1 |
Truck stalls and I've tried all the obvious fixes...
I have a 1971 Chevy Cheyenne with a 350 crate motor. I purchased the truck 6 months ago, and have been working out a lot of its "kinks." My current issue is that it stalls. It occurs when I am at a stop and try to accelerate. Sometimes I can't get it out of the neighborhood, sometimes I drive it around but it struggles most of the time, and sometimes I drive with no issues once I've passed the trouble spot. What I mean by trouble spot is that I've figured out I can very slowly accelerate and once I get to 20 mph or so it will drive regularly. When it is acting up, hitting the gas too hard causes it to die, then I can't start it for 5 to 10 minutes. I have put a new quadrajet carb on it, new mechanical fuel pump, replaced the fuel line from the pump to the carb, replaced the inline fuel filter (added by previous owner due to rust and debris in gas tank), and checked the carb filter for an unexpected clog (even though it's new). It also has new spark plugs. I run 93 octane gas, and have run a few rounds of fuel system cleaner during the first few months of owning it. During the first 5 months of ownership, there was never even a hint of this issue. My fuel gauge doesn't work, so the first time it happened I thought I may have forgotten to fill it up the last time I was supposed to. Any thoughts?
07-04-2015, 04:52 PM | #2 |
Re: Truck stalls and I've tried all the obvious fixes...
Check your fuel pressure. Even a new pump can put out too much pressure. (It happened to me). Sounds like a flooding issue. If your pump is putting out over 5-6 psi then get a fuel pressure regulator designed for low pressure applications and put it between your pump and carb. Many are adjustable.
07-04-2015, 05:14 PM | #3 |
I have seen a choke that stays closed do this.
Jake |
07-04-2015, 05:26 PM | #4 |
All about them K’s
That's what I was gonna say, a stuck choke or improperly adjusted choke.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
07-04-2015, 06:04 PM | #5 |
I'd check the fuel sock inside of thegas tank and located on the fuel sending unit
07-04-2015, 06:14 PM | #6 | |||
"I ain't nobody, dork."
Gary
07-04-2015, 07:48 PM | #7 |
New carb but is the accelerator pump working?
Do you have a heat plate under your carb? Look at the ignition too! What's your initial timing? What distributor do you have? |
07-05-2015, 10:05 PM | #8 |
It was the choke! Thanks everyone for the tips.
Tags |
carburetor, dies, fuel system, missfire, stalling |
