![]() Join Date: May 2013
67 K10 manual steering box problem
I was looking at the manual box on my truck. Turning the steering shaft back and forth, I can see steering box flex where the shaft comes out for the pitman arm. The rest of the box appears solid. I recently noticed a vibration around 45mph and wonder if that is my problem. Any suggestions where I can get a replacement without getting raped? Thanks John
Re: 67 K10 manual steering box problem
All the information I find list the manual steering box as 67-68 only. Will a 69 and up manual box fit? I have a straight six and am not looking to convert to power steering.
Those manual boxes will wear the bearings especially if the gear box oil/grease hasn't been changed. They are not difficult to overhaul.
Is there somewhere I can buy a rebuild kit.
![]() Join Date: Aug 2013
I couldn't find a rebuild kit for mine so I ended up sending it to RedHead to be rebuilt. If I remember right it was around $200.
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
It's my daily driver so I can't really be without it for a couple of weeks.couple
I ordered a rebuild kit from Benchworksteering.com. Kit was $69.95. It is for manual boxes ending in 42 or 80. They were the only ones online that I found. Hope this helps someone else.
In the early 1990's I was working at a GMC dealer. The bearings broke in my '72 Corvette steering box on the way to work.
Surprisingly, they had the bearings in stock and I drove the car home at the end of the day.
![]() Join Date: Sep 2007
is the 4wd and the 2wd different manual boxes? i have a 2wd manual out of my 67 i wont need
1967custom |
I believe the 4wd mounts on the outside and the 2wd mounts on the inside. 4wd is the push pull set up.
