03-27-2017, 07:50 PM | #1 |
"The Peach" 1967 GMC Short Stepside
Picked up a new truck, 67 gmc short bed stepside, came from Georgia hence the name "The Peach"
Inline 250 Straight six (2500 miles on it) Three on the tree, new clutch and seals Dana 44 rear end with 3.54 gears open rear end 6 lug truck, leaf springs in the back Manual drum brakes and manual steering (Yikes the brakes are scary) Truck is relatively straight, it looks like a older restoration, has some rust issues but nothing worse than what I saw locally, plan is to give it power disk brakes, power steering conversion and new paint, and let my mom drive it. I'm more of a squarebody guy so this will be a new learning curve for me, but I am excited that I don't have to smog this truck, and have a 2wd stepper! Pictures: I have already done a few things to it such as: Re tuned the Carb was running VERY rich before, adjusted both doors so no more slamming is required, adjusted the hood to close better, cleaned out the interior, and adjusted the brakes and wheel bearings. This thing is scary to stop, so first order of business is to put power disk brakes on immediately, power steering then its off to paint and body, will be repainted the same color. The engine and transmission run excellent. Not too excited about finding out it had rear leaf springs...but I saw some lowering leaf springs (the truck will receive a mild drop). Will keep this thread updates, and will take more pictures soon.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
03-27-2017, 08:03 PM | #2 |
Re: "The Peach" 1967 GMC Short Stepside
Very nice ,where in Ga did you find it ?
03-27-2017, 08:28 PM | #3 |
My uncle found it in Brunswick Georgia and was able to look at it for me.
Here are some engine pictures:
03-27-2017, 09:11 PM | #4 |
that looks sweet already. gonna be killer when done.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
03-27-2017, 09:22 PM | #5 |
Cool truck. I like it.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
03-28-2017, 02:47 AM | #6 |
Crap, I just realized that this is in the suburban and panel section.
03-28-2017, 12:22 PM | #7 | |
The Older Generation
LockDoc
03-28-2017, 01:32 PM | #8 |
03-30-2017, 02:45 AM | #9 |
Any suggestions for a good quality power disk brake kit?
03-28-2017, 06:28 AM | #10 |
Very nice truck, just as I like em!
12-24-2017, 08:30 AM | #11 |
New bed sides look great! The old ones didn't look too bad in the pictures.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
12-24-2017, 10:53 AM | #12 |
Thanks! The old one do look good in pictures but the tops were bent, tons of bondo in the stake pocket corners, rust pitting all over and to top it off you could surf down the sides of them lol.
12-24-2017, 01:48 PM | #13 |
Look'n good!!!
I'm not an expert concerning what brand of disc conversion parts to buy, but just wanted to make sure you knew some companies make a 6 lug conversion kit that allows you to keep the 6 lug rear brakes. Something to ask about when purchasing brake kit, is whether or not you will be able to retain your stock wheels after conversion. A lot of wheels will not clear the caliper on disc brake applications... Carry On!!! |
02-02-2018, 08:43 PM | #14 |
So I got the rest of the bed finished and I also got the power disc brake conversion done...that was a nightmare so I didn't take any progress pictures. I ended up replacing all the front suspension components while I had it apart. Next up is the power steering conversion. Here are some pictures of the finished power disk brakes, I also had to get new wheels for it.
I ended up replacing all the brake lines on the truck since they did not look to healthy. I also had to get a double flare tool and get new fittings to fit the master cylinder, then I ran out of space to route them nicely so that will have to do for now. Also I put new shocks, as well as 2.5" drop spindles and a 1.5" drop spring for the front. I promise I will take some pictures of the truck all finished up once I get the power steering done. Here is the kit from CPP suspension seems nice so far lets hope it goes better than the disk brake conversion.
02-02-2018, 10:42 PM | #15 |
Real good looking truck! Tuned in
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
04-08-2018, 08:44 PM | #16 |
OK so I did some more things and finally took some pictures. I got the CPP power steering done, install went smoothly no problems. I also converted the trans to a floor shift, I plan on installing a M20 4 speed trans in the future with a big block as well
So after I dropped the front 4" I knew I had to buy some rear lowering leaf springs because the shackles and removed leafs were not cutting it. I ordered them from Western Chassis and they "claim" they are 3" drop. Well, I installed them and sure enough it lifted the truck 1"......fantastic. I really REALLY am starting to dislike the gmc rear leaf springs haha. I might just end up doing a flip kit but I don't know yet. Let me know if you think my truck is dropped 5" in the back, I doubt it. Also got new wheels and tires. Hurst shifter: Power Steering:
04-08-2018, 11:04 PM | #17 |
It definitely doesn’t look like a 5 inch drop, maybe 2 inches from factory height though. A flip kit lowers it 7 inches. I used a two piece Porterbuilt c-notch on my 67 GMC and used stock front shocks for the rear. I do like the stance though it looks great!
Scott |
04-08-2018, 11:14 PM | #18 |
Here is a picture of my GMC which had the flip kit on it. This is a 4 1/2 front and flip kit rear which lowered it 7 inches.
Scott |
04-08-2018, 11:54 PM | #19 |
Great wheel & tire choice!
04-09-2018, 04:10 PM | #20 |
6>8 Plugless........
You have that truck looking pretty sweet now. Can you make a new rear shackle/hanger to get the drop you want to achieve?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-10-2018, 12:42 AM | #21 |
I already have drop shackles installed and a hangar for the front will only lower it 2 inches. I think the springs they sent me are wrong, I sent them a email so we will see what they say.
05-06-2018, 12:13 PM | #22 |
So I ended up keeping the springs and installed drop hangers and took the overloads out of the new "drop" springs and the back looks way better. I need to get the driveshaft shortened now. Up next is rust repair and I might get the paint matched to hold me over for a few years.
12-23-2019, 01:51 PM | #23 |
So I still have this truck, I drove it all spring and fall of this year. I also moved to Idaho in August of 2018 and I drove it up from California to Idaho in December of 2018 talk about cold haha. The truck did great despite the 3000rpm for 900 miles.
While I was down in California for some business a few months ago, I stopped by Classic Industries and picked up a new set of "proper" 67 fenders. So I will be throwing those on soon.
06-19-2020, 12:48 PM | #24 |
05-06-2018, 12:35 PM | #25 |
Funny thing is I actually live and grew up in Brunswick lol
