05-08-2017, 05:33 PM | #1 |
How to swap your sealed 7" to LED
I converted my 7" sealed beam headlights on my '52 GMC to LED bulbs.
I will put links to the parts I used, and pictures on what I had to do. I have now put the same LED bulbs in 3 different vehicles. My friends '07 Jeep, my '67 Jeep, and my '52 GMC all with great results. I'll just say the bulbs work from 9V-32V so if you have a 6V truck it probably won't work.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
05-08-2017, 05:54 PM | #2 |
Re: How to swap your sealed 7" to LED
I will be showing some pictures of my Jeep's lights sometimes but the conversion is the same.
This is the LED bulbs I bought. http://www.ebay.com/itm/Philips-LED-...NZDB8e&vxp=mtr I also bought new H4 headlight plugs from my parts store they where $6 ea.
05-08-2017, 06:02 PM | #3 |
You will also need a after market headlight lens/reflector. I used different ones in my Jeep and GMC it's really personal preference. Both mine use a H4 bulb. You can also find a lens from a newer Jeep 07-15 should work.
First 2 are my GMC Second 2 are my Jeep
05-08-2017, 06:17 PM | #4 |
As for installing it is really quite easy. The H4 ring comes off the bulb install it into lens.
Then you may have to trim the rubber but push it on. Click LED back into ring. 1st ready to go, don't worry about the wires they are for my headlight rings 2nd H4 ring installed 3rd rubber pushed on 4th Led bulb clicked back into place. The last pick is from my Jeep I cut off the red and black you see. GMC http://www.ebay.ca/itm/7-ROUND-DIAMO...item56993ba35f Jeep http://www.ebay.ca/itm/86-95-Suzuki-...item4ac7f40961
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually Last edited by lower50's; 05-08-2017 at 06:30 PM. |
05-08-2017, 06:25 PM | #5 |
After that you should just be able to install like any other stock headlight. Just plug in and go.
This is a low and high beam shot from my GMC And a low and high beam shot from my Jeep for comparison. They are so nice and bright white, easy to see everything. Also the street signs glow.
05-08-2017, 07:44 PM | #6 |
Lower, nice how to on the LED set-up...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
05-08-2017, 07:48 PM | #7 |
Nice job there.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
05-09-2017, 12:49 PM | #8 |
Good write up. Did you see any difference on your electrical system? Since the LED draws a lower current, did you change your headlight fuse to a lower rating?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-09-2017, 03:11 PM | #9 |
Ya voltage gauge dropped a bit before now it doesn't move at all. No I left the fuse the same, won't hurt. The fuse will still blow if there is a short.
05-09-2017, 03:53 PM | #10 |
Thanks, good to know. I was thinking about putting in a 15-20 amp fuse, just as a precaution.
05-09-2017, 04:13 PM | #11 |
It's always a good idea to have fused circuits even if is higher amp than the draw.
05-10-2017, 03:11 AM | #12 |
Any preference ,one over the other ,style you did? Led ring vs, not
05-10-2017, 08:45 AM | #13 | |
Also, are you worried that the rubber seal around the bulb will get hot and melt? I know the heat sink of the bulbs get pretty hot. Here's a picture of mine installed. Thanks again for all of the info! Here's the lights I purchased: http://www.ebay.com/itm/322177905990...AIT&rmvSB=true
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 05-10-2017 at 09:45 AM. |
05-10-2017, 09:26 AM | #14 |
Nice write up. I thought about this on mine as the actual LED complete headlights are super expensive. Mine work great now so I will probably leave them for now as they are.
But these look nice.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
05-10-2017, 03:41 PM | #15 | ||
Ya man, the complete LED light's are crazy. Nice to know there are options.
06-21-2017, 10:23 PM | #16 | |
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
06-22-2017, 08:14 PM | #17 |
That's why we are all here Dan
06-22-2017, 08:48 PM | #18 |
6>8 Plugless........
Nice write up Lower. One other nice feature of these LED type bulbs is most of them have a cooling fan in the back of them to keep them cool and to prevent pre mature failure.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Tags |
7" bulb, convert, how to, led, swap |
