06-19-2017, 02:48 AM | #1 |
rear axle advice
Long time follower on here but i've finally started on my 67.. I'll be running a 5.3/4l80e single turbo, mostly street but definitely will hit the track. I plan on running 4.11's with a posi in the 12 bolt with drag radials. I want to do a c-clip eliminator but saw elsewhere on here that it isn't great on the street? (not sure why). Are the axle shafts ok up to 600ish hp? Do you recommend welding the tubes to the housing? Thanks!
06-19-2017, 10:44 PM | #2 |
Hay Team!!
Re: rear axle advice
Welding the tubes is cheap insurance. I'm running the stock spline count but the axles are Moser. I haven't had any issues and well over 600hp.
1972 Chevrolet Cheyenne LWB "Orange and White" 8) |
06-20-2017, 12:20 AM | #3 |
60-66 Nut
With that much hp/tq I would go with aftermarket axles. Of course the durability of the stock axles will be relative to the size and rubber compound of the rear tires you run. If you do go with aftermarket axles, you may as well narrow the housing a little to accommodate a wider tire and also weld on the correct Moser #7950 housing ends.
06-20-2017, 01:10 AM | #4 |
Call a reputable company, Currie, moser and talk to their tech.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
06-20-2017, 07:36 AM | #5 | |
motor exploder
THIS - don't even mess with C-clip eliminators. Use the Ford Housing ends with GM bolt pattern - that is the correct Moser #, and then get axles from them too. I speak from experience here. I welded my tubes to the housing, narrowed the rear 2", used the Moser 7950 ends and Moser axles with a Moser diff cover/girdle with a Detroit trutrac. Didn't break a sweat taking 600hp. Now it's backing an 800hp Foxwell 532" motor, a modified TKO600 and RAM 10.5" dual disc clutch. I'll report back if anything breaks
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
06-22-2017, 08:20 PM | #6 | |
06-20-2017, 04:55 AM | #7 |
Ok thanks guys
06-20-2017, 05:48 AM | #8 |
Since you're going turbo, use a higher gear ratio to load the engine and get into boost. 3.08, 3.23, 3.42, etc. I've got a 3.25 in my 9" and it works great. 1.62 60' on the footbrake at 4150lbs.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
06-20-2017, 01:35 PM | #9 |
My 468 dyno'd at 600hp and I'm hitting it with a 250 shot. My 12 bolt rear end is completely stock except for a mini-spool in an open diff. Not sure what the truck weighs but its an all stock 68 short bed step side. 3.73 and 28" slicks.
I just tore the rear end apart to re-gear and all looks good. I did however weld the tubes to the center section and added 3" studs. I'm kinda scared of the mini-spool/cross shaft breaking but it looked great. Hopefully it stays together until I can get a full spool and upgraded axles. |
06-20-2017, 11:18 PM | #10 |
meowMEOWmeowMEOW
I run a truck 12bolt @ 3:73, stock width, welded by someone before me. Its had Moser and Strange axles, and survives ok under my fairly heavy truck on steel wheels w/ 325/50/15 MT's. I make a bit less power than some folks, only around 460 + a shot 75-175.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
06-22-2017, 11:24 PM | #11 |
meowMEOWmeowMEOW
^nice trailing arms. Home made or purchased?
06-23-2017, 07:11 AM | #12 |
Thanks. I made them.
06-23-2017, 07:33 AM | #13 |
Thanks for all the info. I originally planned on 4.11's but it seems like a few of you run 3.73's. With the amount of freeway driving in Phoenix I might give the 3.73's a try.. One other question is about how much to shorten the axle for larger tires. I haven't given tire size much thought other than running drag radials. Those of you with shortened axles what size tire do you run and how many inches did you have to cut off?
06-23-2017, 08:02 AM | #14 | |
This photo is old, but shows the bed in place. The truck sits lower now. |
06-23-2017, 05:30 PM | #15 | |
Since I'm being contrary, I don't like drag radials either. Brutal on parts with no sidewall flex and inconsistent unless the track is well prepped. I love a slick for drag racing!
06-23-2017, 08:30 PM | #16 |
100% agreed.
