12-15-2017, 02:23 PM | #1 |
Top of driver door loose
Hey all,
The top half of my driver's side door has gotten loose. I can bend it in and out a couple inches, and when the door shuts it doesn't seal to the weatherstrip at the top. In other words, the window half of the door is somewhat loose. Anyone encountered this, is it as simple as loose bolts or does it need to be repaired? I've already aligned the door pretty well, if I try to suck it in more it won't be flush with the cab. Thanks for your help! |
12-15-2017, 02:59 PM | #2 |
Re: Top of driver door loose
Sounds like you have a crack or a broken hinge. Comes from using doorframe to open and shut door .
Stan 67 swb BLU MULE posted via flip-fone Last edited by harpo231; 12-15-2017 at 03:29 PM. |
12-15-2017, 03:45 PM | #3 | |
Any specific repair ideas? I can take the door apart in the spring and have someone weld a crack...? Thanks folks |
12-15-2017, 03:54 PM | #4 |
You need to inspect it. Can't tell till ya do .
Stan 67 swb BLU MULE posted via flip-fone |
12-15-2017, 04:01 PM | #5 |
the door could be cracked around the top hinge, common issue. Or, if it's just the upper window frame that is loose the weld could be broken at the front (just above the top hinge)
12-16-2017, 09:38 AM | #6 |
12-16-2017, 11:04 AM | #7 |
If it were just not sealing, you can (very) gently bend the upper window frame in by placing a couple of 2x4s in the opening and pressing the door up against them to hold in place (maybe with some soft towels around them if you have nice paint) and then pressing evenly across the top of the window frame to physically bend the door.
BUT, kinda sounds like this isn't your issue - if your door was good before and then now it's bad all of a sudden, well, something has given way. (So don't do the above unless it's JUST the case that your door won't seal at the top). By given way, it almost sounds as though the door's integrity has been compromised. I would suspect a crack at the front lower corner of the window frame - the fwd most portion of the vent window. But won't know til you take a good close look. |
12-16-2017, 11:52 AM | #8 |
I have seen where the window frame welds have failed on a few doors
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
Tags |
door, window |
