09-01-2018, 11:55 AM | #1 |
trans fluid to radiator fitting
I'm getting very close now to installing my Champion CC369 but can't seem to find the correct fittings for the tranny cooler built into it.
In the documentation for this, the fittings for the radiator lines are described as: ..... .....1/2" 20 STRAIGHT THREAD G1/4 ..... I ordered what I though should work from summit but what I got looks more like the fittings that would screw into the 700r4 tranny, not the radiator. My old 4 core copper/brass radiator had the lines connected via two small brass fittings that made the connection from the line to the radiator. These fittings will screw into my new Champion radiator but they aren't going to make a seal as the threads do not really mesh very well and the fitting is loose once threaded in there ( like the threads are incompatible ). What is the fitting I need for this radiator? In the pics below I'm showing the lines from the tranny and the brass fittings I have that will connect to the lines but don't really connect properly to my new radiator. Appreciate any help you guys can offer here. Thanks, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
09-01-2018, 12:46 PM | #2 |
Re: trans fluid to radiator fitting
According to this document:
http://fuelab.com/understanding-fuel...apered-thread/ What I need is a "port-fitting" or one that has straight thread on one end ( sealed with an O-ring ) that goes into the radiator and the cone end has straight thread and a 37 degree cone to go into the line. If that is correct, the brass fittings I have ( the ones I took off the old radiator ) are incorrect as they do not seal with an O-ring against the radiator bung/boss. Looks like the "1/2" 20 STRAIGHT THREAD G1/4" is the standard definition of an in-radiator tranny cooler connection. Can you guys point me in the right direction? I don't want to replace my lines because I can't get a fitting to attach them to my new radiator. What gives? -klb
09-01-2018, 01:34 PM | #3 |
Just called Champion Radiator/LeadFoot Racing at their support line: 714 974 1650, with simple question about what do I need to use to get the tranny lines hooked up.
The guy that answered the phone, claiming to be the owner of the company, totally blew me off like I'm some idiot. Wow! The guy doesn't even know what standard fitting I need? Anybody? -klb
09-01-2018, 01:59 PM | #4 |
I would call the guy back, explain that unless you assist me in correct part to use your product, I will have to let everyone on the internet know about your total lack of customer support....
71 C-20 07 Magnum RT AWD |
09-01-2018, 02:04 PM | #5 |
Do you have a Thread pitch gage?
https://www.lowes.com/pd/IRWIN-Stand...ools-_-1000357 With a pitch gage in hand maybe the local parts stores could help.
09-01-2018, 02:16 PM | #6 |
The guy, turns out, is a re-seller rather than the manufacturer. Still...
Looking down in the hole in the radiator, I see that there is a flare down in there ( inverted flare? ). The fitting I took off my old radiator has the corresponding flare to match that but the threads are incompatible. This is the key: 1/2" 20 STRAIGHT THREAD G1/4 I think this means: 1/2": the bung size in the radiator for the tranny cooler 20: thread count or something to describe the threads STRAIGHT THREAD: parallel rather than tapered thread G1/4: again, describing the threads here I think? However, nothing describes the properties of the flare and how to match up a fitting with it so that it seals properly. I don't know if the fitting needs to seal at the threads, at the flare or with an O-ring. This is not rocket science methinks. There are millions of these fittings in use right now. Surely somebody can make sense out of the above to help me determine what I need. Thanks, -klb
09-01-2018, 02:18 PM | #7 | |
Unfortunately no. All the parts counters around me are useless unless and until you give Year, Make and Model and are looking for something they have on their computer screen.
09-01-2018, 02:50 PM | #8 | |
I forgot about that. There is only a couple around here that are ok to visit. Like joey said I think a regular line would work.
09-01-2018, 02:20 PM | #9 |
I replaced my stock radiator with a Summit-sourced one that was supposed to be factory correct. It looked the part, and I guess it was factory-fitting correct too, because the factory transmission lines threaded in perfectly and have never leaked. As I recall, they were brass with a tapered seat, similar to what you have in your photos. No experience with the "straight thread, no cone, o-ring" setup you're apparently needing.
If the guys who made/sold you the radiator can't tell you what to get and where to get it, maybe they should receive their radiator back. That seems like a major breakdown in basic customer service to me. EDIT: You posted the same time as me. Well, okay, that guy was a reseller. He should still know this, or be able to find out. Or, you could call the manufacturer direct. I think you're on the money with the description - 1/2" x 20 is very straightforward, straight thread sounds to me like they're specifically saying no NPT fittings, and I have no idea on the G1/4. Never seen that before.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
09-01-2018, 02:42 PM | #10 |
Moderator
I have 2 champion cc369 radiators, one in a truck with a th400, the other with a th350. I just reused the brass fittings that were in my oem radiators and have had no issues.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-01-2018, 03:27 PM | #11 |
I definitely hear what you're saying about the threads being different. And I'm definitely not saying the factory fittings should be used with the new radiator (I think Getter may have gotten me confused with LeddZepp).
If I were you, I'd use a precision caliper to measure the bore, a thread gauge to measure the TPI, and see if I could research an adaptor fitting that used those measurements while also being compatible to the factory fitting on the other end. Essentially, a brass plug that turns the aluminum radiator's fitting into the one you need for the tranny lines.
09-01-2018, 04:58 PM | #12 | |
This is what I need. Just don't know yet how to measure properly the female radiator port. I can measure ID ( It's over 1/2" just barely ) and then get the thread tool to measure the TPI. But, that doesn't tell me what "brand" threads those are, whether American, British, etc and/or what type of seal is required. Maybe the thread tool will discern those things?
Guess I'm off to Lowes or someplace to find that tool. Thanks, Quote:
09-01-2018, 03:32 PM | #13 |
Oh, nice! An adaptor - just male/male, not male/female as I was suggesting. For future reference, you know for certain that smaller male side is compatible with the tranny line fitting?
09-01-2018, 03:41 PM | #14 |
Yes.
Thanks,
09-01-2018, 04:05 PM | #15 |
Moderator
Summit Racing also carry a suitable fitting under
https://www.summitracing.com/parts/ear-940006erlp Its an Earls product, sold as a pair... These use a flat crushable washer instead of an O ring... Work well as pressures well under 100 PSI in clloer circuits, even if you use lock up convertor... Now back to assembling my new trans...6L80E...to go behind my 6.0.... |
09-01-2018, 04:08 PM | #16 | |
I purchased these EAR-940006 fittings for 20 bucks thinking they were what I needed. But alas, no. I have them right here and they do not screw into this radiator.
-klb Quote:
09-01-2018, 04:19 PM | #17 |
Moderator
Was this a special build radiator?
What is the part number on the radiator...? I have two CC 369 rads here in projects and both accepted the Earls fittings....snug and no leaks... Beginning to believe this radiator is not marked correctly... Do you have a good hardware store near you ? Go buy yourself a 1/2" 20 TPI bolt...it should screw directly into the radiator bung... If its as loose as the fitting is... send the radiator back to the seller and find another source... Not a plug...but old jeggy always looks after me https://www.jegs.com/i/Champion-Cool...CC369/10002/-1 Have them send you the fittings as well.... |
09-01-2018, 05:17 PM | #18 |
A thread pitch gauge is handy to have around, for sure.
But it sounds like Aussie is onto something - I'd check out the 5 AN fitting he's linking to on Grainger, see if the other end fits your line fittings.
09-01-2018, 05:24 PM | #19 |
I have no idea what I have because both radiators should have standard ports for these lines.
I was just pointing out that the fittings suggested a few posts back by Aussie were definitely not correct as I had already purchased them and confirmed they would not work ( Earls ) some weeks ago. Here's the link from his post: https://www.summitracing.com/parts/ear-940006erlp, which are the same parts I once thought I needed too. Obviously not. I need to measure this radiator port, actually both radiators, to determine why my original fitting doesn't work, then attempt to find a fitting that does. This should be easy. -klb
09-01-2018, 06:23 PM | #20 |
Moderator
If you are Lowes, grab a 1/2" 20 bolt and try it in the radiator....
The thread count per inch is listed by the manufacturer as 20...thats where the 1/2" 20 comes from in the listing 1/2" diameter 20 TPI The standard hydraulic flare angle is 37 degrees...Parker fittings make some that are 30/37....mainly for aircraft use.... If you want to do some reading on AN vs standard flare...see.... http://blog.parker.com/an-37-flare-v...the-difference I checked with a tech guy at Jegs that I know well... The Earls fitting listed and what you purchased goes into the transmission itself....not the radiator....he told me they should update the text of the part description to reflect that... He also said that most folk now dont use the radiator cooler at all...they close off the bungs with plugs and run external coolers..... If the project I was working on was high horsepower, that's the way I would also go... The current projects are both "stockers"...around 350 / 350...both early 350's... |
09-01-2018, 08:06 PM | #21 |
Went to two auto parts stores looking for a bbc timing tab. Neither had it in stock and both struggled hard to identify what I was after exactly.
Anyway while there I us d their bolt size tool to confirm my brass adapter is 1/2 20. Both ends of it. I picked up a 1/2 20 bolt at Lowe’s. When I’m finished with this I’ll test it all n the radiator Posted via Mobile Device |
09-01-2018, 08:53 PM | #22 |
Moderator
That looks so yummy....!!!
Try that bolt in the radiator....I still think the radiator is the wrong one or has been specially built and stocked wrong.... I use the 1/2 20 fittings from Grainger and have never had an issue.... Have a great night |
09-02-2018, 12:20 AM | #23 |
they should be 1/2" x 20 inverted flare, as in a 45 degree flair, like a fuel or brake line, you can most times use a off the shelf 5/16 brake line that already has the fittings on them at oreillys for your transmission cooler line. i just installed a champion radiator in a c-10 and did this. i have seen some champion radiators that didn't use the inverted flair, those will use an adapter that has 1/4 npt fittings to 1/2 inverted female. yours should be 1/2 x 20 inverted male looking
at that pics you posted... |
09-02-2018, 07:44 PM | #24 |
Moderator
I believe in one of my first threads I suggested you go to Lowes and buy a 1/2" 20 bolt to verify the threads were as listed...obviously this radiator is a special build thta has probably been sold to multiple poor souls.
Call the seller and send it back...even if you have to pay the freight... Then go to a reputable supplier and buy it, along with the fittings you need from the same vendor.....if they cant supply you the fittings...call Champion Cooling and demand an explanation ! I have always had excellent service from Jegs...but others like Summit etc also know the value of good customer relations. |
09-02-2018, 07:58 PM | #25 | |
I think what you need is a fitting with male G1/4 on one side (goes in the radiator) and male 1/2-20 on the other side (trans hose attaches to).
1972 GMC 1500 Super Custom, 383 Stoker, TH350 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592157 Engine Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592233 |
