05-05-2019, 05:31 PM | #1 |
52 pickup door panel (interior)
This will show how I do some door panels. This one is again a no sew, it is all done with glue and staples. I will take you through the entire build. First I will show you the materials I used. I started this panel back on April 1st for a friend, took this pic the other day. This door panel will be made to match a pleat design in his seats. It should be noted that the pics show it took a little over a month to finish the job, it was actually 8 days work, with life getting in the way the rest
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 05-05-2019 at 08:34 PM. |
05-05-2019, 05:35 PM | #2 |
Re: 52 pickup door panel (interior)
ill be watching
05-05-2019, 05:38 PM | #3 |
Hey Greg, just getting started will take a few days. Will post a link for the other guys later..Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
05-05-2019, 05:47 PM | #4 |
I normally use 1/8" lauan to make my panels. Ed could get only 3/16" so this makes it a little harder to bend the way I want, but still doable. (forget to mention that the panels were made out of one sheet of 4'X8' lauan sheet)
Pic 1. I have already cut the lauan to fit the door, and drew up how the panel should look. I had placed the arm rest shere Ed wanted, drew the outline, then I put dots where I wanted to drill holes for mounting of arm rest. Pic 2. Taped arm in place on panel. Pic 3. Drilled back thru holes to mark arm rest. Pic 4. I then followed instructions for arm rest. Drilled holes out to 3/8" so I could install inserts. Pic 5. View from back side.
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 05-05-2019 at 07:03 PM. Reason: added info |
05-05-2019, 07:07 PM | #5 |
Pic 1 View from back side of panel with screws installed to hold arm rest.
Pic 2 Arm rest attached to door. Pic 3 Started cutting 2" wide stripes to make up pleats, total of 28. I know they look short, but they're not.
05-05-2019, 07:12 PM | #6 |
The next 3 pics are showing the arch I made to match the arch of the arm rest.
First pic is bad, but the next two shows what I did. After looking at the dates on the pics, I should tell you that I have other things going on, and I work on the panel when I have time (plus I'm and old fart).
05-05-2019, 11:21 PM | #7 |
I take it you bought the armrest...care to share where they can be had...still gonna be awhile before I need stuff like this for my AD ...but all good info...
05-05-2019, 11:28 PM | #8 |
I think Ed got them from the company that bought out Rod doors. Maybe Chevy's of the 40's...Jim
05-05-2019, 11:42 PM | #9 |
Pic 1. This is the passenger panel, ran short on lauan, but had some old stuff in the basement to use. Just a different type of wood, light is birch, dark is walnut. Again about a week has gone bye.
Pic 2. I've cut material to fit all the panels. Take you time and measure twice or more before cutting, if you only have a small amount of material. On the pleated part, make sure to have extra length to go into the pleat, plus normal length. Pic 3 Top section cut Pic 4 Bottom section and for arm rest. All of this was cut from 1 yd of material for each panel, 36" X 54"
05-05-2019, 11:52 PM | #10 |
Pic 1 I start out doing about 4 pleats at a time. Spray the panel, then the material, use a brush to get in the pleat. Let everything set for about 5 minutes to tach up. Start smoothing the material on the flat surface, then feed material into low spots. I'm sorry I got ahead of myself and forgot pics of how to do this, but I show it on the drivers panel later.
Pic 2 Here is the first 4 pleats, that have been pressed into the low spot with bondo spreader or screen door roller. Continue doing about 4 or 5 pleats till finished. Pic 3 Then glue to back side and staple down. Pic 4 Remove extra material.
05-05-2019, 11:56 PM | #11 |
Pic 1 This is the bottom section, I've stapled material at bottom of pleats. Again I forgot pics showing glueing bottom lauan section then glueing the material to it. It's the same for the top section, which I did take pics. When your doing this work you forget that you need to take pics, just get caught up in the glueing etc.
Pic 2 How the bottom section came out.
05-05-2019, 11:45 PM | #12 |
Subscribed
05-05-2019, 11:59 PM | #13 |
Thanks b-mac
Well it's late, will post more tomorrow...Jim
05-06-2019, 07:29 AM | #14 |
Those turned out great, very nice work.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
05-06-2019, 09:41 PM | #15 |
Hope this may help someone that want's a easy panel to build for their ride. Any questions, I will try to answer.
05-06-2019, 09:45 PM | #16 |
For those that find this thread, I should also mention that I did another style of door panels, back about 4 yrs ago. It has alot more detail on that panel. Here is the link http://67-72chevytrucks.com/vboard/s...d.php?t=662380 ...Jim
05-07-2019, 08:14 AM | #17 |
Jim, that is great work. Thank you for sharing.
05-07-2019, 09:09 AM | #18 |
Robert, Thank you. I don't do interior work very much, so I thought it might help someone. Thanks again for checking in out...Jim
05-07-2019, 10:54 AM | #19 |
That's a really great write up! Thank you. A couple of questions, how are you going to attach the panel to the door? And, if you have the door release lever and a window crank, i.e. a TF truck, do you cut those hole before or after the material is laid down?
05-07-2019, 04:47 PM | #20 | |
I would cut the holes first to fit everything and make sure they work. You could always make the hole larger for clearance, but a small cut in material would allow the crank to come thru...Jim
05-08-2019, 01:10 AM | #21 |
Beautiful work Jim. I double checked and I don't think you mentioned the spacing for the slats.
Roger |
05-08-2019, 09:13 AM | #22 |
Thanks Roger. Most of the time I use 1/4" for spacing, this allows material on both sides of the slat and looks good. Thanks for checking out the thread...Jim
05-10-2019, 02:23 PM | #23 | |
rick |
05-10-2019, 11:51 PM | #24 | |
05-08-2019, 10:19 AM | #25 |
do you think the 3-m glue you used would work for a headliner repair on a 78 chev truck. Can,t buy the proper landeau contact cement here in Canada
