Corona Project!
Well, one thing I have learned from this pandemic is bad s**t can happen quickly! This truck has been in the family for 40 years and in my care ( or lack there of) for 20 years. Life kept getting in the way and two major house remodels came first. Well no more excuses and collecting parts so I cleared a hole in the garage and pushed her in. I have watched with interest how so many talented people have created great projects on this site so hopefully some of it sank in. Anyway, I know you like pictures so here are some of where I am starting from with my 47.1 GMC.
Re: Corona Project!
Out with the old and dead.. I forgot how much cast iron there is in the front end of this thing.
Re: Corona Project!
That's a great truck to start with. Nice to see a '47 1st design. Years ago, I thought all '47s were this style and '48 was the first year Advance Design.
Re: Corona Project!
So I found a surprise when I removed the Heater/Defrost unit. Were heaters optional on this truck? Anyway, I was surprised to find a Ford heater and there did not seem to be a surplus of holes in the firewall to indicate there had been a different heater installed. So far I have not found too many Warts for the age of the truck. I did give up on trying to unbolt the small fasteners with Phillips heads, even with lots of WD40 they were not coming apart. Luckily most broke with a little more tightening. Removing the rivets has been a little more fun!
Re: Corona Project!
I have been working on filling the Swiss Cheese holes in the frame. (Good welding practice) There are hundreds of them and while I get the removed rivets caused some, I have no idea what a lot of the other holes are for. Anyway, I built a cab dolly and the cab came off today so I can get at the rest of the holes. Then I will send the frame out for blasting and a good prime before starting the rebuild.
Re: Corona Project!
Nice work! I'm in for the build!
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 |
Re: Corona Project!
Looking forward to seeing this build!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Re: Corona Project!
docrock - Nice green 42! as I get further into the rebuild I am sure I will have questions on how it goes back together.
Thealien - wow, lots of interesting links for that hard to find info on swaps I will be checking out. |
![]() Join Date: Sep 2016
Re: Corona Project!
Nice start for the truck! What are your plans for it?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
Re: Corona Project!
Goodbye to 73 years of rust and crud. Now to start getting wheels back under this thing.
Gigamanx - plans are to modernize the powertrain so that it is fun to drive again and hopefully do some cruising. I have a Mustang II front kit so that will add PS and disc brakes. The rear will be an Explorer 8.8 with 3.73 gears, limited slip and disc brakes. How do you like driving your 49 on air? I am toying with air suspension on this thing for a good ride. Power will be from the General. |
#11 | |
Re: Corona Project!
My current build I am not bagging just due to cost. I had some coil overs for the rear already so it didn't make sense to try bag it. I'm just going to set the ride height real low for the coil over mounts and avoid speed bumps ![]()
![]() Join Date: Sep 2017
Re: Corona Project!
Great truck to start with. Looking forward to more progress.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
Re: Corona Project!
8man - Nice work on the 48 AD. lots of good ideas there.
Well I have been busy working on the front suspension and have made a little progress. Not a big fan of the instructions that say measure back 16 inches and weld away!. Have been boxing and measuring and measuring and fitting and measuring.... you know the drill. I think I am getting close so put the cab back on and will try a fender in the next couple of days to see if the wheel still fits in the opening before I get carried away making things permanent. |
![]() ![]() Join Date: Mar 2016
Re: Corona Project!
I like the idea of artillery wheels. But, I think it will look good whatever you choose.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
#15 |
Moderator
![]() Join Date: Jun 2008
Re: Corona Project!
Very nice! I can't wait to see this build progress.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
#16 |
Re: Corona Project!
Time for some pics as I had the day off to tinker a bit. I decided to stuff the motor in the hole to see if it would fit and what was going to be an issue. The good news is the hood will still fit but I will need a shorter engine oil pan and will have to do something about exhaust manifolds. None of this was a big surprise but you never know until you have it in place. Do any of you transmission experts know if there is a shallower 6L80E trans pan than the truck one I have now? I will also have to think about a radiator and fan but it looks tight up front.
#17 |
Re: Corona Project!
Nice work and a good solid truck to start with.....
http://67-72chevytrucks.com/vboard/s...82#post8619382 |
#18 |
Re: Corona Project!
Oldcarguy; Thanks for looking.
Time for an update. Thanks to Santa Holley the oil pan does not hang below the front cross member any more. The exhaust manifolds no longer sit on the frame thanks to some Hooker manifolds that tuck in tighter to the engine and don't have pipe flanges that stick out to the sides. Time now to come up with some engine and trans mounts.
Kermitt's 47 truck build |
#19 |
Re: Corona Project!
That engine sitting there looks great.
#20 |
Re: Corona Project!
Looks *****in! Great stance.
#21 |
Re: Corona Project!
Just found your build. I’ll be following. What Gen V engine do you have there?
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
#22 |
Any updates?
#23 |
Re: Corona Project!
Everything is on Hold while we pack up the house and shop and move to the Island. Hope to be back at it full time this summer. Glad to see you are having fun with your old Chevy.
#24 |
Catchy title goes here..
![]() Join Date: Mar 2002
Re: Corona Project!
I was wondering about this too. Good luck on the move, update when you can
#25 |
Re: Corona Project!
Any updates??
