08-11-2020, 04:16 PM | #1 |
74 step tail lights stopped working
I've been doing a bunch of reading through threads on here, but wanted to make sure best way to do this.
Basically, last night my running tail lights stopped working. I had an issue with the truck where the truck wouldn't shut off. After much troubleshooting, I determined the moron working on my exhaust pushed the positive battery cable at the starter into the terminal with the ignition wire, so I was getting constant voltage to the coil and it fried the coil. I adjusted the cable, replaced the coil, and issue solved. Except now my tail lights don't come on. Brake lights, dash lights, side marker lights and directionals all work. I partially dropped my tilt column to check my ignition switch when I was dealing with the coil issue (thinking the ignition switch was the problem), but really didn't move much of anything around other than the switch. Not sure if I somehow pinched a wire. As such, and from my reading, this is not a fuse issue, and most likely a ground issue, correct? Also, I'm guessing it's not a bulb as both sides are out? I'm in AZ, so not much rust here, but stuff still does get rust, so not sure if the mount to body ground on the tail light housing is the issue. Just weird it happened all of a sudden while I had this coil issue. |
08-11-2020, 09:23 PM | #2 |
Re: 74 step tail lights stopped working
I recommend always check the bulbs first. Then use a multimeter or test light probe to check the bulb sockets for presence of voltage. If you can also test that the bulb socket is grounded using the same tester.
08-11-2020, 09:29 PM | #3 |
Thanks. I’ll do that first and go from there who knows last time they were changed.
08-12-2020, 06:37 AM | #4 | |
08-12-2020, 07:43 AM | #5 | |
Msgt USAF Ret
The side marker lights are part of the tail light circuit (I think) so that means you should have power on the brown wire for the tail lights which only leaves the tail light bulb filiments. I would disconnect the rear connector and check the tail light wire (brown), for power and If you have it, that only leaves the bulbs. I like the troubleshooting that's been given by everyone so far, very good.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
