09-13-2020, 01:15 PM | #1 |
Sanden 508 Wiring
Hey wondering if anyone could help me out got a new sanden 508 for an original ac truck and need to wire it. A black and a dark green wire go into the og compressor. The sanden only has one black wire. I’m assuming that because the dark green is switched 12v from the poa valve/pressure switch that, that dark green wire should go directly to the black wire on the sanden? Is that the case? Have any of y’all done it? Is there another way I should be wiring it? Anything helps thanks!
09-13-2020, 09:21 PM | #2 |
Old member
Re: Sanden 508 Wiring
Dark green is hot and the black is a ground with a diode if I remember correctly.
So yes you would tie the DG into the new compressor for 12 volts. I'm not going to say use the black without you furnishing a picture of it though to confirm.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-14-2020, 11:58 PM | #3 |
Msgt USAF Ret
Look at the 1 minute mark and the clutch only has the single black wire. He says the coil is grounded so the black wire has to be the hot wire for the green to connect to. If you have a voltmeter measure the ohms between the black wire and the coil. If you get some resistance then you are reading the coil windings resistance and the black wire is the hot wire and the coil is grounded to the compressor body.
https://video.search.yahoo.com/yhs/s...46&action=view
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
09-15-2020, 12:44 PM | #4 |
Thank you I think we are in the same page and I’ll do some testing this afternoon. But it would be awesome if you link directly to a YouTube video I’m fairly sure my yahoo isn’t pulling up the same video. Another question closely related would y’all know what this little connecting wire with a black ball(see picture attached) on it is because if dark green is power and black is ground they shouldn’t be connected right?
09-16-2020, 09:24 PM | #5 | |
Msgt USAF Ret
https://youtu.be/w3aqgpKz5nI
09-16-2020, 07:47 PM | #6 | |
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
09-15-2020, 08:47 PM | #7 |
That's the diode Andy spoke of.. It "clamps" the voltage spikes created when the magnetic field collapses as current is removed from the coil windings..
09-16-2020, 12:53 PM | #8 |
So that black diode shouldn’t be necessary for the sanden?
Tags |
air conditioning, compressor, wiring |
