06-23-2021, 12:30 PM | #1 |
correct length of 350 oil dipstick
I lost the original dipstick the my 79 and so replaced it with a junyard dipstick but now it seems like it is to long. I just changed oil 5 quarts and it is way over the full line. I thought sbc dipsticks were all the same but I guess not. Can someone give me the correct length? So when I go back to the junkyard I can get the right one.
79 Chevy 2wd BIG10 350 TH400 |
06-23-2021, 02:36 PM | #2 | |
Re: correct length of 350 oil dipstick
Get the tube with it.
06-23-2021, 04:03 PM | #3 |
I hate to replace the tube. My 76 350 dipstick is 18 1/2" from under the cap to the end.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
06-24-2021, 01:29 AM | #4 |
If you know for sure the amount oil that your truck took you could just re-mark the dip-stick. Just do not use any van dip-stick in your truck cut it down re-mark it. you have to get the same engine and oil pan as your had( yr, dip stick side left or right, in-let tube style, stock pan or not )
I hope some of this may help
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
06-24-2021, 09:06 AM | #5 |
I have one on the wall from a 75 350. Dipstick measures 19 1/2 and tube measures 6 1/2 from top of tube to block
06-24-2021, 11:52 AM | #6 |
Looks like these dip sticks are all over the place.
My 75 350 has a 8 inch long tube and a 21 inch long shaft.
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
06-24-2021, 09:12 PM | #7 |
06-26-2021, 06:43 PM | #8 |
Old Heap Driver
On my hot rod builds I use an aftermarket stick.... Add 4 quarts of oil with a new filter.....Start the car, run it a minute or so, check and mark the stick, add the last quart, run the car, mark the stick, done
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '30 Model A Pickup, suicide front end, 350, 350, traditional style hot rod. |
06-24-2021, 12:44 PM | #9 |
76 350. 21” dipstick with a green cap end.
