07-20-2021, 01:57 PM | #1 |
5.3 & 4L60E swap in 72 K10 question
So I am planning to start this project soon. I am going to use the advance Adapters kit 50-5310 to mate the 4L60E to the NP205 transfer case.(figure 8 bolt pattern) My question is about the clearance between the CV yoke (spicer) and the transmission. AA states in their instructions that there might be clearance issues. They did not have any specifics and referred me to High Angle Drive Line. They said with my front shaft angle at 15 degrees I am right at the limit. Truck is lifted 4 inches. Anyone out there with this clearance issue? Trying not to spend $750 on adapter kit and installing the shaft in the 4L60E only not to be able to install the front shaft. Thanks for any input.
07-20-2021, 04:51 PM | #2 |
Re: 5.3 & 4L60E swap in 72 K10 question
The driveshaft should clear with the lift.
You need a rear speed sensor to make the transmission shift. Are you going to mate a VSS to your 205?
07-20-2021, 04:53 PM | #3 |
The advance adapters 4 bolt to 6 bolt NP205 adapter has the VSS provision.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
07-20-2021, 04:52 PM | #4 |
I had pictures of the interference and what I did to alleviate it in one of the links in my signature. But I have been unable to find them, sorry.
I didn't have a lift, your 2" should help. I ended up cutting the corner of the pan and having it welded back on backwards. It worked and I never had a problem. To me the transmission pan interference is the biggest negative about an LS/4L60 4 X $ swap. I have looked into the transfer case that comes with an LS pull out and changing the front axle to a drivers side drop (which is what the 4L60 was designed to be used with). That option has its own issues. You should be OK dimpling the pan?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 Last edited by Thealien; 07-20-2021 at 05:22 PM. |
07-20-2021, 06:38 PM | #5 |
Thanks for the input, I plan to use the provision in the adapter for my VSS. As far as the lift helping, I was told that the lift would make clearance worse. I don't see how that can be since the shaft is going down away from the pan right from the T-case. I can notch the pan if it's a little to close. I have a lot of things to figure out. I do have a complete 04 Tahoe as the donor so I have all the goods from it.
07-22-2021, 12:28 PM | #6 |
I have installed a 5.3/ 4L60E and kept the NP205 in my 72 Blazer. I am running a 2" lift and it looks like driveshaft clearance will be tight but I have not installed it yet. I used the AA kit and Dirty Dingo engine mount. So far I am pleased with the swap, still have a few more details to sort out.
07-22-2021, 12:55 PM | #7 |
I have the AA 4l60e to NP205 in my Jimmy with a 4" lift. I ended up notching the pan like Thealien said. If i remember correctly it would have cleared with a 1/16th of an inch but that is way too close in my opinion. The last thing i wanted was tranny fluid on a hot exhaust pipe. That's a fire that you wont put out.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
07-30-2021, 09:35 AM | #8 |
I have a 2 inch lift with 4l60e/np205, front drive shaft was very close I just dented the corner of the pan with a block of wood and hammer and now have clearance
08-28-2021, 09:33 PM | #9 |
Roto Reuter thats the name...
I put a 5.3 LM7 4l60e in my 70 K10. The clearance is tight for sure. I did a little grinding work on the yoke. I did not have to dimple, hit or dent the transmission pan. I also used the VSS signal in the AA NP205 to 4l60e adapter. I made a special plug for the vacated spot in the NP205. You can check out my build thread in my signature.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
10-01-2022, 05:52 AM | #10 |
Hey guys I'm doing the same swap here but the kit didn't come with instructions and this is the only thing I can find on their website.
file:///C:/Users/Mader/Downloads/50-5310-1.pdf Does anyone have a link to better instructions? I'm not having any luck finding anything.
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
