01-10-2023, 08:46 PM | #1 |
1975 K5 Prep for softtopper
I bought a white softopper for the 75 a few years back - haven't got round to putting it on but 2023 is the year I think. However, the frame for the softtopper bolts into the threaded sockets that the hard top uses underneath rails of the bed and not all of mine are serviceable.
Has anyone replaced or repaired these? I figure I'd need to drill and tap some small slices of steel plate but not sure how I'd fix them in place. |
01-22-2023, 03:48 PM | #2 |
Re: 1975 K5 Prep for softtopper
Bueller?
01-23-2023, 06:36 AM | #3 |
Just here to tinker
Might want to ask this question in the paint/body work section in the general forum. The blazer/sub section is usually a ghost town.
Good luck!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
01-23-2023, 07:33 AM | #4 |
If the captive nuts are no longer serviceable could you remove or drill the bad ones out and just use a nut!
Those captive nuts are held in similar to door hinges so the nuts/plates have some movement or at least that’s how they are on my 1972 Blazer(s). When you look up under the rail you should be able to see them. You would need to remove the bedside trim panels to see them. Not sure how to explain but you could cut one end of the captive assembly so you could slide the old threaded piece out and slide a new one in. If you were carefull cutting the end there could be enough material to fold back over and keep it from falling out?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
