02-14-2023, 12:02 AM | #1 |
2002 Tahoe starts and then dies
I'm working on an 02 for a friend of mine and he said after replacing the battery it started doing this. The only code I find is a 1626. I put a new GM ignition switch in it and nothing changed. The security light also stays on even when the key is removed. Also the automatic head lamps dont come on when you turn the key on but you can turn them on manually. The dome lights dont work and neither does the remote. Has anyone ever experienced this? I have read a lot and watched a lot of things but nothing covers what issues I am having.
98 Neon 97 Grand Prix GT 02 Grand Prix 40th Anniv. 86 GMC 5.0 77 Olds 98 6.6 REAL AMERICANS, DRIVE AMERICAN |
02-14-2023, 02:30 AM | #2 |
Re: 2002 Tahoe starts and then dies
You need to do a passlock reset. Plenty of info and videos out there on the procedure.
Customization is what you want it to look like -- not what other people think it should look like |
02-20-2023, 06:30 PM | #3 |
Moderator
To reset Your 2002 Chevy Silverado security system put the key in the ignition, turn the key to the on position, and leave it on until the security light goes out.
Usually abut 15 mins. Once this happens crank the truck without turning the key backward, just turn to start. This will reprogRam the transponder from the ignition switch. To prevent someone from using a fake or non-registered key, GM installed an anti-theft system called Passlock. When the wrong key or other tool is used to crank the ignition, the Passlock system disables the truck's fuel system.
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
03-03-2023, 09:48 PM | #4 |
That procedure doesn't work, I haven't done anything with it for a while and am still looking for an answer.
04-02-2023, 11:41 AM | #5 | |
,1. Insert a master key (black head) into the ignition switch. 2. Turn key to the “ON ” position without starting the engine. The security light should turn on and stay on. 3. Wait for 10 minutes or until the security light turns off. 4. Turn key to the “OFF ” position for 5 seconds. 5. Turn key to the “ON ” position without starting the engine. Security light should turn on and stay on. 6. Wait for 10 minutes or until the security light turns off. 7. Turn key to the “OFF ” position for 5 seconds. 8. Turn key to the “ON ” position without starting the engine The security light should turn on and stay on. 9. Wait for 10 minutes or until the security light turns off. 10. Turn key to the “OFF ” position. The key transponder information will be learned on the next start cycle. 11. Start the vehicle. If the vehicle starts and runs normally, the relearn is complete. 12. If additional keys need to be relearned, turn the key to the “OFF ” position. 13. Insert the next key to be learned. Turn the key to the “ON ” position within 10 seconds of removing the previously used key. 14. Wait for security light to turn off. It should happen fairly quickly. You may not notice the lamp as the transponder value will be learned immediately. 15. Repeat steps 12 through 14 for any additional keys
03-04-2023, 04:58 AM | #6 | |
The answer is that the security system is malfunctioning. I had to defeat it on mine.
