11-06-2023, 01:52 PM | #1 |
issue with traction
OK, I seem to have a serious issue with traction(actually the lack of it) on my friend 68. It's lowered 4.5/6.75 and never adjusted the pinion angle. Would the correct angle help with traction? if so, what angle do we need to shoot for?
11-06-2023, 02:28 PM | #2 |
Re: issue with traction
No.
Pinion angle has nothing to do with traction. You do, however, want the rear pinion working angle to be 3 degrees for u joint life and smoothness. Equal and opposite to the front joint would be ideal. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-06-2023, 04:28 PM | #3 |
Do you have leafs or truck arms
11-11-2023, 04:10 PM | #4 |
If it has trailing arms you'll need to raise the front pivot points up, preferably above the axle tube height for the most effective increase in traction. You can buy brackets to replace the originals that have multiple holes for tuning the pivot height, or you can remove the stock brackets and flip the over.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
