02-17-2024, 03:32 PM | #1 |
Active Member
68C10 front suspension overhaul
I have a 68c10 with 6 lug drum currently. Front is pretty worn and I’m getting a list together to make an order. I currently have 3 nub 15” wheels and am aware of disc brake kit rubbing. I will use whatever spacer to get me by until I get different wheels. I am staying 6 lug. Truck is setting on a CPP 3/5 spring kit with shocks and long adj panhard bar right now. I want to upgrade to 73-87 arms, ball joints and tie rods. Will keep it manual 68 gear box for the time being. eBay has tubular upper/lower arm kit out of Arizona with 73-87 ball joints has anyone used these?
02-17-2024, 03:35 PM | #2 |
Active Member
Re: 68C10 front suspension overhaul
Next thing this is the kit I found on eBay it’s CPP disc setup.
02-17-2024, 03:36 PM | #3 |
Active Member
If both of those setups are right all I would need to complete the front would be tie rods, drag links and wheel spacers correct
02-18-2024, 02:32 PM | #4 |
Active Member
Figure someone might have chimed in about the a-arms. They look almost identical to CPP ones
02-18-2024, 02:47 PM | #5 |
This thread has information about front suspension swaps.
Link: https://67-72chevytrucks.com/vboard/....php?p=4450757 Hope this helps.
02-18-2024, 05:09 PM | #6 |
I recommend do whatever it takes to stay stock Chevy parts, post want-to-buy ads in the parts section to get what you need from 71-72 model years. Unless there is actually something wrong with your A-arms they would not need replacing. Personally I would not have anything by CPP on my truck, and would not use spacers to try to make non-disc-brake-compatible wheels fit. It would be significantly easier to get some 5-lug rally wheels that just fit. Just my 2¢ and I apologize if it's not useful advice, and I'm not trying to be critical; I just have read too many OMG threads on this forum about the state of aftermarket parts and what brake and suspension systems people have found themselves dealing with and fabrication to work around problems.
02-18-2024, 06:35 PM | #7 | |
Active Member
02-18-2024, 06:59 PM | #8 | |
02-18-2024, 06:19 PM | #9 |
I'm not being critical, but it seems to me you're making this way more complex and expensive than it has to be.. Dimple the frame for a power steering box. Use a '71 - '72 or '73 - '80 something front crossmember. Include in the "salvage yard grab" all the steering linkage, control arms, springs, spindles, rotors, and calipers.. No fabricating, no spacers, or adaptors needed for anything. Everything is bolt-on and parts are available at most auto parts stores.
02-18-2024, 06:38 PM | #10 | |
Active Member
02-18-2024, 09:17 PM | #11 |
Dimple the frame while nothing is in the way.. Then, at a later date, if you should decide to install power steering, the dimple work is done.
02-18-2024, 10:57 PM | #12 |
02-19-2024, 12:23 PM | #13 | |
Active Member
02-19-2024, 01:40 PM | #14 | |
Active Member
02-18-2024, 06:51 PM | #15 |
Active Member
Im not really set on rebuilding oem vs buying an updated arm. I am taking everything in as constructive criticism and learning from the forum daily. Definitely going to do disc and 2.5 lowered spindles. My wheels will get changed out one day to a larger diameter and therefore bring the truck back up in overall height. This is another option i have thought about.
02-18-2024, 07:00 PM | #16 |
I just mention this stuff because I notice you're a premium member here and have the ability to buy and sell on the forum.
02-21-2024, 12:04 AM | #17 |
63-72 a-arms shafts are a much better/more durable design than the softer 73-87 rubber bushings that degrade and deflect, and I'd bet they'll also outlast aftermarket urethane/delrin bushings found on tubular arms. The original cross shafts/bushings looked brand new with no wear at 150k on my truck. New shafts are dirt cheap on rockauto and come with new seals.
I'd stick with the stock arms, do the caster mod on the lower control arm shaft (thats the only benefit those tubular arms usually offer-added caster), and use CPP's 63-70 disc brake kit. 1.50" bolt on spacers will clear the studs and calipers with stock drum brake wheels. It'll drive really well with those mods and track dead straight at interstate speeds. Steering effort will be pretty high in parking lots with added caster and added scrub radius from skinny wheels with spacers but if my skinny arms can deal with it I'm sure yours can deal with it until you get power steering That's the recipe I used on my '66 and it drives great other than heavy steering in parking lots. Spend the money you save on tubular arms on power steering instead. I have a Borgeson box waiting to go on mine when I get some spare time.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
02-21-2024, 01:22 AM | #18 | |
Active Member
02-22-2024, 08:35 AM | #19 |
I second what theastronaut says. When I rebuilt the upper arms on my '72 with new cross shafts, they were a bit tricky to get the threads to line up but once you get it right they rotate perfectly and with virtually no squish since they are steel. Drill a new locating hole in the lower shaft for more caster. Most go 3/4" forward on the lower arm, but when I did that my spring was rubbing the crossmember. I went to 3/8" forward and added power steering and that was the magic combo for me. That coupled with all new tierods and balljoints and it drives quite well. I also have 4 nub 5x5 wheels so they clear the calipers without spacers.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
