04-28-2024, 01:56 PM | #1 |
Spray Max 1K E-Coat Primer
Anyone used this epoxy primer for small areas?
I bought 3 cans to try out. Used the white e primer fixing small rust removal repairs on inner fender lips . Color actually matched dodge ram truck white https://www.coastairbrush.com/prodde...at_Primer_GRAY
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
04-28-2024, 05:38 PM | #2 |
Re: Spray Max 1K E-Coat Primer
That's what I used (gray color) over the bare metal areas before I started filler. It sprayed real well.
Just for the fun of it |
04-29-2024, 12:53 AM | #3 |
Did you use the 1K stuff like in the picture?
I got the 1k so I do small areas and re use the can many times until its empty I think the 2k rattle can stuff you have to spray the whole can at once or waste what is left in the can 2k would be more durable with the hardener . Not sure how durable the 1k non hardener is
04-29-2024, 07:20 AM | #4 |
I did use the 2k I think there is a 72 hour wndow to use. It dosent cover a lot of area. I used used 4 cans pretty fast.
05-02-2024, 12:08 PM | #5 |
If you're using the 1k primer. You need to check the tech sheet for what you want to top coat it with. ( assuming your not just rattle canning it ). Most modern/current products. Will advise you against/not applying them over a 1k product.
