06-24-2011, 01:21 PM | #1 |
Always a work in progress
1985 Radiator Options
I didn't want to hijack the thread for a 63-66 radiator so I figured I would start one for my truck.
I planned on getting a new radiator to go along with my swap. Plan 1: I can get a new alum 3 core with dual elec fans from champion for $315. It is set-up just like a stock radiator with the inlet and outlet on opposite sides. Plan 2: Entropy has one with the inlet/outlet on the passenger side and the trans cooler on the driver's side. That 1 costs $699 w/elec fans. I like the 2nd option bc it cleans up the engine bay but has a hefty price tag. What would you do? Anyone have some pics of their engine bay with the stock style radiator showing how you routed the hoses?
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
06-24-2011, 01:55 PM | #2 |
Re: 1985 Radiator Options
Nrd, I have the Champion radiator myself, I have dual elec fans also, I like it, it works great, fits with no mods and also has the trans cooler in it. When I looked at this, I thought why spend ( I was looking at Be Cool) $1000.00 for a rad/fan combo? besides if it didnt work out, I had thrown good $ after bad before.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-25-2011, 04:52 PM | #3 |
where can I find Champion radiators at? Sounds like a pretty good deal for radiator, fans and all....
06-25-2011, 06:35 PM | #4 |
Randy,
See Ebay TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
06-25-2011, 08:53 PM | #5 |
I am getting mine from reliable radiator
06-25-2011, 10:45 PM | #6 |
Im using the stock 85 radiator & fan shroud with stock 04 fan, fan clutch & radiator hoses. The only mod I made was soldering a 3/8" adapter to the heater hose nipple on the radiator for the steam hose. It work great! 100+ degrees outside idling in the sun with the A/C on.....No overheating or A/C head pressure problems.
I have terrible luck with aftermarket parts on my own vehicles. It seems my customers & others have better luck |
06-26-2011, 11:11 AM | #7 |
That is where I got mine
06-26-2011, 09:36 AM | #8 |
I used a radiator out of a 99 Suburban, with trans and oil coolers built in, 40 bucks at the local yard. Then a generic elec fan from summit. The truck runs 190-205 even when towing a 7klb load....
06-27-2011, 01:25 AM | #9 | |
Posted via Mobile Device |
06-26-2011, 05:08 PM | #10 |
I would use my stock one with an electric fan but it barely keeps my 305 cool(It's a 6cyl truck) and it's an eye sore. When I install the 6.0 I want to clean up the engine bay at the same time. For $310 shipped w/ dual electric fans, I can't beat that. I have read alot of good stuff about champion raditors so i don't really have any issues with purchasing one.
06-26-2011, 06:51 PM | #11 |
if I had any issue with them, I would blab it to anyone who would listen. I got a bad fan and I called them, told them about it, they set a replacement that day and I had it is 2 days.
06-28-2011, 07:45 AM | #12 |
I had to custom mount it. It is a little wide for the core support, but it works. I installed a rubber mount on the lower part of the core support then use the stock upper mounts with rubber bumpers installed in them to hold the radiator in.
09-04-2011, 08:43 AM | #13 |
just an fyi, the champion with dual fans is down to about 290$ shipped now of ebay from reliable
09-05-2011, 12:11 PM | #14 |
I just purchased this for my truck, couldn't justify spending over $600.00 for an Entropy setup. I will post pics when it comes in.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
09-05-2011, 06:37 PM | #15 |
can you post a link to this, i can not find it. Thanks Daniel.
09-05-2011, 08:41 PM | #16 |
09-06-2011, 10:42 AM | #17 |
meowMEOWmeowMEOW
I run the be-cool and im happy with it, but since the PO put it in the truck when it became a 350 years back, I didn't have to foot the bill for it.
If it wasn't mentioned, the F**d Taurus fan setup is popular for going e-fan on the cheap. A dual fan setup with temp sender from a pick n pull is like $35
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
