Old 08-05-2010, 10:00 AM   #1
kefers
1968 Panel Truck 4x4 Frame
Wanting to turn my panel truck into a 4x4 . Is their a factory truck frame or suburban frame that will work or do I just find a donor 4x4 truck and replace drivetrain?
kefers is offline   Reply With Quote
Old 08-05-2010, 10:44 AM   #2
John Fabris
TOTY 2006
John Fabris's Avatar
Re: 1968 Panel Truck 4x4 Frame
I am planning on doing the same thing. Several options, easiest is to find a 4x4 suburban or panel frame. Or you could use truck longbed 4x4 frame but end of frame is different and body mounts are different. Last, you could convert your 2wd frame.
I am planning on converting my 2wd frame, modify frame to fit front leafs, and I am putting rear axel under my trailing arms.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-05-2010, 12:06 PM   #3
Steven B
Steven B's Avatar
I started doing the same conversion on my panel before I sold it. I was using a 68 Suburban 4x4 frame and converted it to 72 3/4 running gear. The easiest conversion would be to find a Suburban 4x4 frame. Also make sure to install a high hump to clear the trans and transfer case.
70 Jimmy 4x4
71 GMC 2500
Too bad stupidity isn't painful
Steven B is offline   Reply With Quote
Old 08-05-2010, 02:57 PM   #4
big blue 72
Kefers, First of all, "Welcome" to the best board on the planet for any info on chevy trucks!
WE all love to see pictures of any panel truck in any condition. Care to share?Keep reading here and others will chime in and help steer you towards your goal. Glad to have you aboard!
Broken Back Club
72 Club
GMC Club
Panel truck Club
6 cylinder Club
Unfinished Projects Club
Outdoor Sportsmens Club
big blue 72 is offline   Reply With Quote
Old 08-05-2010, 04:23 PM   #5
jbclassix
Junk Yartist
jbclassix's Avatar
edited..................................by staff
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 08-23-2010, 12:26 PM   #6
kefers
Are there any later model 4x4 suspensions that will bolt up?
Old 08-05-2010, 09:53 PM   #7
John Fabris
TOTY 2006
wheelbase, for longbed trucks and suburbans and panels are the same, but the truck frame at the end (rear of frame) are different as well as the body mounts (no completely positive about body mounts though).
John Fabris
67 C10 SWB
Old 08-25-2010, 08:05 AM   #8
olblue60@aol.com
member
I did the replacement . I put a 67 panel on a 72 4x4 suburban frame. It bolted right up! Later models have a 4 inch longer wheelbase.
John
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 08-26-2010, 12:44 PM   #9
scotto0609
Junior Member
Originally Posted by olblue60@aol.com View Post
I did the replacement . I put a 67 panel on a 72 4x4 suburban frame. It bolted right up! John
I did the same exact thing!!
scotto0609 is offline   Reply With Quote
