Starter Heat Shield for headers?
Hey, I put some headers on my truck the other day and after running if for awhile it would not start but after cooling down the starter turned over just fine. I would like to know what you all used for starter heat shields? This is new to me never had this problem before. EJ
![]() Join Date: Feb 2001
wrapit
I have one of the wraps from Summit. About 24 bucks. I was replacing a started every year, but this seems to be helping.
CCRider
Or if your cheap, a campells soup can cut in half longways,a piece of fiberglass insulation, and tyewire works too
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
I think a remote Solenoid (sp?) will also help.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
![]() Join Date: Jan 2001
Location: Katy, TX...but the love of my life resides in Dublin,OH.
I have a Moroso heat shield it works quite well... Jegs sells them for 22.00. You can probably pick one up for about that at your local parts house. But they are a necessity with headers... I just can't keep the plug wires off mine.
I had the same problem on the 327 I had in my truck. I did something similar to the soup can trick except I used two aluminum beer cans (after properly disposing of the contents) and attached them to the solenoid with a hose clamp. Worked great.
Randy aka "Fast Orange" 1972 Chevy Stepside that will one day be finished!! |
![]() Join Date: Jul 2000
Another good argument for shorty headers! Seriously, I have a brand new Summit stainless steel heat shield you can have for $20 including shipping to MO. Summit and Jeg's charge around $8 shipping per order, so you'd be into them for over $30. The shield will fit most small blocks up to 350. Are your 2 starter mounting bolts in-line or offest?
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
mabe I am wierd but,I have never had to use a heat sheild even on my 600hp 454. I think the remote starter solenold is the way to go though.
69-C10 LWB 71- fleetside shortbed It's a shame stupidity isn't painful Never play leapfrog with a unicorn |
Let's see, assuming 500 lb/ft of torque at 6300 rpm, you get 600hp. Man, that's some motor! What are you using for a trans, driveshaft, diff, and axles?
EJ- go to any parts store and look at their "help" rack. You know, the one with all the extra door handles and window cranks? Anyway, I got a starter heat shield off of one of those racks for under 10 bucks and it has worked fine for nearly 5 years now. If it isnt there then look in the aftermarket parts area. I've seen them there for less then 10 bucks as well. good luck
100% Beefcake
J C Whitney sells a nice one. It is stainless steel with an heat resistant wrap. I cant remember what I paid for it.
1969 C10,350,4:11 posi, Fast Enough 1984 Monte Carlo SS 1987 Chevy S-10, 355 w/150 Shot of Nitrous, Fun,Fun 1938 Nash Lafayette 1956 MG Magnette |
Guys thanks for the help. my local parts store has the sheilds I just didnt notice before. EJ
