Old 11-12-2019, 04:06 PM   #1
Nightrider
Nightrider's Avatar
87 on a 74 frame
i was wondering will a 1987 cab and bed etc will fit on a 1974 k20. both single cab long beds of course. some feedback would be nice thank you
] : - 71' burb,5.3,4wd
02' f350.7.3
00' F250-powerstroke
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Nightrider is offline   Reply With Quote
Old 11-12-2019, 06:03 PM   #2
sweetk30
sweetk30's Avatar
Re: 87 on a 74 frame
body mounts to frame vintage 73-80 or 81-87-91 .
otherwise bolt it up . maybe need floor pan work if the hump is 2wd on the 87 and the frame being 4wd . the later/newer body's had no unbolting dog house .
also fuel filler necks get them from the 87 . and the fuel hose might need some work . early tanks had a smaller inlet size for the fillers . or just use the 87 tanks and be done with it .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-15-2019, 12:18 PM   #3
Honest Bob
Honest Bob's Avatar
I'm putting my 75 long bed single cab on an 86? cucv frame and the only thing I found so far is on the second set of holes on the bed coming from the cab are different and will need to be drilled in the frame. This doesnt seem to be well known.
You will have to use body mounts that match the year of the frame.
Also I found the one fuel tank mounting bracket was different between my frames.
Honest Bob is offline   Reply With Quote
