I6 & V8 throttle the same?
as the title say's, are the 6 and v8 throttle (the arm the rod from carb) hooks up to the same length? mine seems a little short and my tk was org a 235. here is a pic of mine in the middle.
1961 chevy K10 my build is------------61K10 build |
Enjoy your truck
Re: I6 & V8 throttle the same?
The I6 and V8 linkages are different under the hood.
The V8 arm is taller than the I6 arm. Greg
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
the arm on the engine side of the bellcrank is of a different length. just get a v8 one
ron |
I bought one for a tri-5 chevy v8 about 1 1/2" longer by looks. mine works but is a little touch-e (quick) thanks for the reply's.
Mine was originally an I6 and the PO put in a sbc. I believe he used the original arm as my pedal is really touchy. Would getting a longer arm make it less touchy?
the longer that arm the quicker the response. that means the shorter distance that the pedal travels
ron |
I got another arm and cut it drilled two holes and bolted it to six cylinder arm using linkage hole and drilled extra hole also have done same thing using small piece of aluminum has worked great
I just recently made a new linkage rod for my SBC swap and it too seems very touchy with the short l6 style arm. I might try to lengthen the arm as well to see if that makes the throttle action manageable. The geometry of the lever certainly impacts the amount of travel.
If that doesn't work I may need to search for a mid-70s pedal assembly that I saw on someone's 64-66 that worked much better.
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
I did te mid 70's throttle cable mod, and love it.
Now if I could just eliminate my sticky accel pump, my throttle action would be perfect |
